Question about Retail Supplies
I have a Berger dumpy level of unknown model and vintage. the only markings that I can find on it are: 3H 3017, WARRENTY 3301. The cross-hair & a light stop have been removed & I do not know where to replace them in the system. Can anybody help me. or even post an assembly diagram together with more info. re model etc.
3 Suggested Answers
  • 4 Answers
SOURCE: Oreck XL How to remove rear wheel.
You can take a medium size flathead screwdriver and slide it in beside the wheel and under the pin. Then pry carefully on one side and then the other it will start to come out but work both sides alternately so you won't put too much pressure on the plastic. Once it is out you can clean it and put it back in. Line up the pin and use a blunt end tool like a punch to tap it back in. You can use the same screwdriver but don't hit it too hard. You can tell when it is in all the way when it bottoms out. Make sure you look closely at it before you take it out so you will know what it is suppose to look like.
Posted on Mar 26, 2010
agent91
  • 2100 Answers
SOURCE: I have a berger instruments transit level model
Yes there is, but I don't think you can do it your self. There are places that fix nothing but levels and transits. I don't know what happened to your lines, must have been dropped or something. I had a level repaired once, it was fairly cheap. I would contact Berger first. Hope this helps.
Posted on Aug 09, 2010
How to raise feed dog?
look in the instruction manual, the information should be in there
Apr 09, 2016 | Sewing Machines
Crosshairs are broken in Starrett No. 99E Telescopic Transit
I too am looking for an answer to this, my cross hairs are gone on my Starrett 101 A transit. Not even sure how to take it apart to look at repairing it myself. Just bought it.
Apr 18, 2014 | Buyenlarge The Berger Complete Engineers...
My image on antique dumpy level is upsidedown, how do you invert it ?
You cannot invert it on antique dumpy levels. Modern dump level are designed with optics that do not invert the image.
Apr 14, 2013 | Computers & Internet
How to fix loose cross hair on david white transit
This is how I replaced the cross hairs on my David White 8080. Disassemble the tube piece nearest the eye. There is a small ring that holds the hairs, it has small marks on it to indicate where the hairs are to be attached. Use a large lighted magnifying glass. Remove the old hairs. Take some plastic model glue and using a toothpick, place a very small amount on the marks to anchor the new hairs. This type of glue will produce strings or "hairs" when beginning to dry if you use a toothpick to stretch them out. Place some drying glue (several seconds old out of the tube) on one of the marks, and pull the toothpick away (creating a hair) and pull it across the ring to the mark on the other side. Repeat for the second cross hair. With a little practice you can make some very nice cross hairs.
Dec 16, 2012 | David White 44 8834 1 22x Level Transit...
Berger transit won't focus
If you mean your cross hairs wont focus the most likely cause is the cover you are turning is slipping and not actually adjusting the lens. Depending on the model, there are usually a couple small screws that can be tightened to correct this.
If you mean what you're trying to look at (objective) wont focus, then likely the focus tube is no longer making contact with the focus pinion. Look in the objective of your transit, and you should see a tube inside the frame. Turn the focus knob slowly and see if it moves the tube closer and further away. If not the rack and pinion are no longer meshed up. If it does then you have a lens out of place. Disassembly is easy, but reassembly and realigning the lenses is tricky, i would not recommend. A repair shop should be able to take care of this, and make sure it's in proper calibration for not to high a cost.
Nov 10, 2012 | Cst Berger Measuring Tools & Sensors
If we are excavating a drain and i have to level the drain how would i use dumpy level to know how much i have to excavate
Use a tape measure or a wooden pole marked off in inches. Start either end and look at your measurement. then dig accordingly. down hill add inches uphill subtract inches.
Feb 03, 2011 | Craftsman 20 Power Dumpy Level
I have a berger instruments transit level model 200B and have no cross hairs to center it when i look through it , is there a fix??
Aug 09, 2010 | Speed Berger Instruments Line Transit -...
Depth measurement using a dumpy level.
first level it up in all directions then take a shot of your tape measure or marker stick at the predetermined point, write this measurement down, then take a shot of your tapemeasure reaching down in the excavation and then subtract the predetermined measurment from the excavation measurment and this will tell you how much deeper your are than your predetermined mark.
Jan 31, 2009 | Craftsman 20 Power Dumpy Level
No sound
Check device manager and see if it shows up there. if you have a yellow question mark or red x, install or re-install driver by right clicking on your sound card and uninstall and scan for hardware changes.
Please let me know how you make out.
Dec 09, 2007 | IBM ThinkPad 600X Notebook
Retail Supplies Logo
133 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
