Question about Lands Phones
One tel sigma 2200. No dial tone.
All other phone sounds work. BT socket works with wired phone. Changed rj11 cable and still no dial tone. Have registered the two handsets to the base. Any help appreciated
  • Lands Phones Master
  • 3,497 Answers
Are you using dsl broadband this could interfere . Type of signalling may be a problem. If multi tone or decadic on phone line does not match phone settings but I would expect you hear dial tone. do you have cable plugged into a phone socket it could be a internet rj45 socket.They look the same at the wall especially in an office environment.
Posted on May 08, 2014
  • 146 Answers
SOURCE: No Dial Tone
I have found this free link on BT site for you
http://www.shop.bt.com/content/uni2/documentation/498n/025455.pdf
If the second handset works ok on the base and the first handset doesn't, then you are right...the fault lies with the first handset. There are batteries ( special type ) in the handset, it sound as if either the batteries are dead, or not charged ( try charging them for 12 hours on the good base station ) or the connection is bad.
Posted on Jan 14, 2008
  • 14 Answers
SOURCE: Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Posted on Apr 01, 2008
  • 5 Answers
SOURCE: my phone keeps saying unable to connect
is your phone about a year old? It may be the battery. The vtech phones have weak batteries that clunk out after about a year and you'll get dropped calls, looking for base etc... The phone still appears to be working and the battery indicator tells you it's charged, but the battery is too weak to keep the wireless connection going.
Had the same problem and replaced the battery. budgetbatteries.com had the cheapest ones. But it's a knockoff, so I don't know how long it will last. So far it's been 3 months and the problems are gone. I would try that first and see how it goes. I paid about $15 including shipping. If you buy it from vtech it's at least double...
Posted on Jan 31, 2009
RPFinney
  • 385 Answers
SOURCE: cordless phone not connecting to base. no dial tone.
switch the A/C mains off 5 minutes
or
Re-register them to the base,
This resolves the problem
Regards
Richard.
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: No dial tone. Base will ring. Handset has no
Check the Battery on the Handset. remove the pwr frm the base unit n connect aft 30 sec. aft this if it still says the same msg, then the handset needs to be replaced.
Posted on Mar 04, 2010
Chat to customer agent landline reported to faults still not repaired
Where I live, my landline company is responsible only up to a "demarcation point" - this is a box on the wall near where the phone line enters the house.
There is an RJ11 socket on the box,
chat-customer-agent-landline-reported-2iujiwfvuy020nygunv3yc1j-5-0.jpg and the technician (or you) plugs a known-working phone into the socket, and listens for a dial tone. If there's no dial tone, then the tech takes corrective action - replacing cable, or confirming correct operation of the distribution box on the boulevard / utility pole, or contacting billing to reactivate the line.
If I dial 611 from my or a neighbour's landline, they'll typically have tech to my door in 24 hours.
Beyond the 'demarcation point' (ie inside my house), it is my responsibility to ensure the internal phone wiring is operational.
Check your local thrift stores for a replacement phone, if necessary.
Your local hardware store will likely carry a 'tone & probe" set, which will indicate if a phone socket is wired properly, and can be used to follow a wire through walls / ceilings / floors.
Pro3000 Analog Tone and Probe
Mar 17, 2015 | Lands Phones
Phone displays error message "check tel line
The phone is not detecting dial tone on the line. Are you able to hear a dial tone? If not - disconnect the cable at the phone and plug into a different phone. If it works, then the problem is with the Panasonic phone - if it doesn't work - the problem is with the cable, jack, wiring, etc.
Mar 12, 2015 | Panasonic Lands Phones
Talk talk my account
Since you didn't mention the brand/model/type of your phone, I assumed it's an analog one directly connected to your internal Tel Central or Public Tel Exchange.
Try one of the following isolation:
1. Replace your phone with a known good one. If dial tone exist, then your previous phone is faulty.
2. Replace your line cord with known good one. Maybe one of the connector (RJ11) is faulty.
3. Check the wiring connection in the face plate or tel outlet. Maybe there's loose contact somewhere.
Jul 20, 2014 | Lands Phones
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
I have a BT installed ADSL RJ11 socket with two wires - Blue and Blue/White going to pins 4 and 5 respectively for ADSL only. I want to install a new RJ11 module socket but connecting these wires to pins 4...
That is the BT side of the wiring and should not be touched .. It sounds like you are trying to install an extension and should use a punchdown tool to extend the existing socket to a new box.
Full cabling details with pictures at http://www.wppltd.demon.co.uk/WPP/Wiring/UK_telephone/uk_telephone.html
Hope this helps? .. if it does, please leave feedback - if not, please let me know and I'll see what I can do to help!
Dec 29, 2009 | Computers & Internet
I have a dial tone, but cannot receive or send faxes
After trying everything, I reset the machine to factory settings (press Menu, then 7 for Maintenance). I then also changed the fax cable to the telephone socket. Despite a computer shop telling me that I need a BT to RJ11 cable (I think this is a modem cable), the correct thing is to use a simple telephone cable. The look exactly the same from the outside (both plugs), but apparently they are wired differently which may not be visible from the outside. Now it suddenly works again!
Jan 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
BT Freestyle 2200
I think the internal ringer is a default and cannot be changed, but the external ringer can be changed.e03e2a2.jpg
Jun 26, 2008 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
No Dial Tone
May 08, 2007 | British Telecom Synergy 2110 Cordless...
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
