Question about Cub Cadet Garden
How can I tell if my starter is bad on my cub cadet rtz mower
I have 2009 Briggs and Stratton 50 in zero turn mower that won't turn over. I have changed the spark plug and that did not work. The mower will sound like it is going to start but the engine never catches. When I am trying to start it the battery goes from 12 down to 9.8 on the meter. It has gas. What do you recommend
Check for spark
Have to get the test plug for small engines
Is the battery years old & partially dead?
Is the oil clean & full
Won't turn over or won't start?
Clean the flywheel & ignition coil or whatever
system it has for spark
Check for intake gasket leaks.
Did the meter always go down to 9.8 when it did start?
Your best to work on things & learn-- when they work correctly,
not wait for years then be lost
Posted on May 08, 2014
  • Brad Lay
    Brad Lay May 10, 2014
    The battery is brand new, as well as the spark plug, and the fuse. The battery always drops when I try to start it but I took the battery in today and it was bad. I installed the new battery and it still won't start. When I turn the key it sounds like it will start but it does not.
  • 67 Answers
SOURCE: Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Posted on Sep 01, 2009
  • 6468 Answers
SOURCE: cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Posted on Apr 04, 2012
SOURCE: CUB CADET RZT 50 VT WILL NOT CRANK. TAKE OUT ONE SPARK PLUG WILL CRANK. PUT PLUG BACK IN AND WILL CRANK AND START. WONDERING WHY?
It may have just been a bad connection to the spark plug. By taking the wire on and off you may have cleaned it enough to work. Also the cable may have some trouble and removing and reinstalling put it in a different position.
Posted on Apr 21, 2012
  • 7 Answers
SOURCE: My cub cadet zero turn won't run. Changed pluggs
Try cleaning the carburetor that might mean that it is not getting gas
Posted on Apr 18, 2013
Cub cadet RTZ L54 Zero turn dies after a few
Sounds like a fuel problem. Dirty carb or could be a dirty gas filter thats in the gas tank.
Sep 30, 2014 | Garden
Possible dirty carb
Clean fuel jet before you pull it apart.
I have a cub cadet rzt zero turn lawn mower that I'm trying to get started need to know how to adjust the valves on the mower
Can't say with knowing what engine you have such as Kawasaki, Kohler or, Briggs and Stratton.
Apr 17, 2014 | Garden
I have an cub cadet rtz 50 briggs and stratton 26hp motor. I'm trying to take off the starter. I got the bolt closest to the oil spout off. The other one is a booger. Its so close to the round part of the...
I've always pulled the flywheel off, the last thing you want happening is that bolt backing out because you couldn't get it torqued tight enough after you replaced it. That backed out bolt can do a lot of damage not only to the flywheel but to your new starter as well.
Oct 28, 2013 | Garden
Apr 17, 2013 | Garden
I have a z force s cub cadet. The battery is good. Tested and passed. the engine/started must work hard to turn over, but still won't catch. I will jump the tractor and it will start and run.
You may want to try to find a battery with a stronger amperage rating. Even if the battery passes if it is borderline for starting it new it may not be strong enough even if it's still okay for it's battery type.
Other causes:
A worn starter can cause this issue. If a few of the coils shorted the starter will work but require much more current to do the job
A bad relay/solenoid to the starter that doesn't allow enough current to go through can cause this.
Valves out of adjustment... especially on some Briggs and Stratton engines, it's a known issue that if the valves need adjustment the motor can require a lot of energy to turn over and can cause constant hard starts.
Mar 28, 2013 | Mtd Cub Cadet 48 In 22 HP Kawasaki Engine...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Garden Logo
103 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
