The fault in our stars ar test answers - Office Equipment & Supplies
How do i get ar tests answers for free
What sort of printer is an AR.
If it is not a printer then why use this form of media?
Sep 09, 2014 | Office Equipment & Supplies
Service l6 10
Sharp AR-M207 . Enter these keys one after the other to reset:
  1. # - * - C - *(pound, star, C, star).
  2. The screen will go blank and ask you to enter a code
  3. Enter "14" and press the print button.
  4. It comes back and asks if you are sure(showing "1" as default). Press enter.
  5. Machine should then reset
Aug 21, 2013 | Sharp AR-275 Copier
I've got a 2008 Yamaha Road Star with Vance & Hines pipes a a Power commander III USB which was dyno-tuned not more than three weeks ago, they created a custom map for me and the bike was running...
Hi, Jeffcitychri the answer to this question is way above my pay grade but I would go back to the Dyno people also for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re Engine Codes 2008 1700 68 24 Road Star Forum Yamaha Road Star
Yamaha Fault Codes
Yamaha XV1700PCRC Service Manual
OEM parts for Yamaha
Yamaha XV1700PCR Road Star Warrior Owner Manual
Apr 15, 2017 | 2007 Yamaha Road Star
How do I reset the Sharp AR-M205 Copier please?
On the key pad P * C * sim 14
pound star clear star sim 14
Aug 24, 2010 | Sharp AR-M205 Copier
Error Message - L4-03 What is wrong?
If you had paper jams it will display this error after 3 in a row in the fuser. Double check to make sure all paper is removed from the fuser. To reset, on the keypad press pound star clear star and enter sim 14 and press copy button. reset copier it should turn off and on, test if paper jams there may still be something stuck.
Aug 24, 2010 | Sharp AR-M550U Copier
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
129 people viewed this question
jasbo
jasbo
