Question about Numark ICDX CD / MP3 / DVD Table Top Player IPOD
What does the error code MP3 NG mean? - Numark ICDX CD / MP3 / DVD Table Top Player IPOD
Error code 80 sub ng. What does this mean?
The manufacturer of the device will tell you what the code is all about.
Sep 08, 2017 | Office Equipment & Supplies
Hi! i am trying to detect a problem in my sony model HCD-GZR777DA when switch it on, after waiting it display c 31 00. where to start please help
31: DPD offset adjustment error .
Contact any service technician. You can't repair this. The error code list to this set:
The meaning of error code is as below:
01: Communication error (No reply from syscon)
02: Syscon hung up
03: Power OFF request when syscon hung up
19: Thermal shutdown
24: MoveSledHome error
25: Mechanical move error (5 Changer)
26: Mechanical move stack error
30: DC motor adjustment error
32: TE balance adjustment error
33: TE sensor adjustment error
34: TE loop gain adjustment error
35: FE loop gain adjustment error
36: Bad jitter after adjustment
40: Focus NG
42: Focus layer jump NG
51: Spindle stop error
52: Open kick spindle error
60: Focus on error
61: Seek fail error
62: Read Q data/ID error
70: Lead in data read fail
71: TOC read time out (CD)
80: Can't buffering
81: Unknown media type
Are you confident to do anything with these error displays.
If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Sony Audio Players & Recorders
Displaying....DSP NG can some one please help? some kind of error.
In my experience, NG on a system made in Japan means "No Good" (error). NG might stand for something else, but regardless, it sounds like an internal issue with the amp.
Sep 24, 2015 | Pioneer VSX-D510 Receiver
I have a Noritz tankless water heater (model n-132m). I am getting an error code of 71. What does that mean?
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
Sep 12, 2014 | Noritz Commerical Tankless Water Heater...
What does error e000225-0001 mean
see the cable inside the scener unit is broken or check foil conctvity
Dec 26, 2013 | Canon imageRUNNER C5800 Copier
What does NG mean in the TX/RX log?
NG just means the fax was unsuccessful or No Good. After the NG should be another number code that tells what type of error it was. Could be busy on the other end, poor line quality, or any number of things.
Jan 12, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Print activity report on my canon pixma mp830 and the result is NG.. trying to find what that means
NG only means the result is No Good. After the ng there should be an error number that tells what the problem is.
Nov 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Showing warning psd ng in dvx102 panasonic video cam
PSD NG means that there is a problem with your electronic image stabilization system.I think Panasonic got stuck with a bad batch of gyros. Take it back if you can, otherwise use lower resolution or hold very still when filming.
Mar 26, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Need list of Fax result codes for Canon MF5550
NG 070 = Issue: ERROR LCD: CLEAR ADF, DOCUMENT TOO LONG
Solution: Reduce the length of the document
Reduce the length of the document to within 14" (356 mm).
Sep 03, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Numark ICDX CD / MP3 / DVD Table Top Player IPOD Logo
Top Numark Computers & Internet Experts
Mike
aravind shet
aravind shet
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
