Question about Watches
What battery does the DKNY Men's Digital watch #DY-NY1367 watch take
VOTIT
  • 2071 Answers
SOURCE: Replacement battery for DKNY NY1050
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
disap1
  • 98 Answers
SOURCE: resize DKNY 1035 Wrist Watch band
Could be a number of different ways. Some newer watches have multiple clasps that make it easier for you to adjust it yourself. Check the bottom of the band for extra clasps.
Without seeing the watch I have no idea what type of links you have. I suggest taking it to a reputable watch repair shop and have them adjust it for you! It will save you the frustration of having to search for a small screw or pin if it should fall on the floor!
Posted on Jan 10, 2010
  • 2501 Answers
SOURCE: HI there!
I doubt if any watch maker makes their own batteries so any battery that is the correct size should do the job.
Posted on May 19, 2010
SOURCE: I have a DKNY watch which has a slim rubber starp
I found my DKNY watch ******** http://www.bablas.co.uk/watch-straps/dkny-watch-straps.html
Posted on Jun 06, 2012
How I set time on a men dkny digital watch
http://www.watchstation.com/wcsstore/CommonWatchStation/content/shell/brand_guides/DKNY/instructions/DKNY_Inst_ENG.pdf
Jun 05, 2015 | DKNY Watches
What battery is in the DKNY Ny Twist watch?
I had to look into this for my wife's DKNY watch and this particular model has a Ronda 751 quartz movement, which takes a 379 battery. You can verify this by entering the movement name 'Ronda 751' and you'll see pictures of the movement with a 379 battery inserted.
Jan 07, 2014 | DKNY Ny4634 Twist Watch
Battery
A professional can do it with a special machine
May 22, 2013 | DKNY Leather #NY1328 Watch for Men
Hi - I bought a DKNY NY1304 watch three years ago, and unfortunately my digital screen just broke. I was wondering if it is possible to replace it with a new device? The only information given for the...
You have to speak to your nearest DKNY distributor - they might help you and carry out necessary repairs. Alternatively visit your nearest watch repair shop and ask if they can help.
Jul 31, 2010 | DKNY NY1304 Watch for Men
How do you set the time
its has a button there press it to set the time
Jun 19, 2010 | DKNY NY1308 Watch for Men
How do I change battery.
mcdevito75 here, You:d need a couple of watch tools to change the battery, the cost of these tools and the cost of a watch repair shop to change the battery for you are similar. Look for a small watch repair shop in your area to save on the cost of replaceing the battery.
Jun 17, 2010 | DKNY Leather #NY1328 Watch for Men
Need screw for watch Style#NY-4285
Hi, you should be able to get one from a watchmaker
Jun 16, 2009 | DKNY NY5045 Watch for Men
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
