What do I do My Honeywell thermostat T8411R is not working. Its display is dark
The display is dark it is not a thermostat that requires batteries. I have checked all circuit breakers and outlets that are connected to the unit.
  • 130 Answers
The thermostat wire may have and break and not getting power. Honeywell Customer Assistance at 1-800-468-1502
Posted on May 09, 2014
Heat pump compressor/fan/air handler runs heat for 30 secs, then all stop. (Trane XR 11 HP w/honeywell T8411R thermostat). Capacitor good, new 5-2-1 hard-start kit added but didn't solve problem.
Sounds like low pressure. Are you losing low voltage to condenser? Backup heat not working likely due to a setting error or possibly a wiring issue.
Nov 14, 2016 | Heating & Cooling
I have A LCD Honeywell thermostat that has a display that is blank. also it is not sending anything to my furnace. there for my main level in my house is very cold. I have the same one up stairs and it is...
Replace the batteries first. Some cheap thermostats require the batteries to function. I don't know of a honeywell model that does though. Its cheap, so do that first.
If still nothing comes on and you still have a blank display with new batteries, I'd say probably the thermostat is defective. Even if the furnace is broken, new batteries SHOULD bring up the display.
Feb 20, 2015 | Heating & Cooling
Honeywell t8411r
Not enough information. Are we talking heating or cooling? Makes a difference.
Feb 05, 2014 | Heating & Cooling
Honeywell Thermostat for gas fireplace not working
sir there is some probalm in LED change it for use
Jan 25, 2014 | Honeywell Heating & Cooling
I am replacing an T8411R with RTHL3550 and I have the following wires. Original vs New G=G,R=R,Y=Y,O=O......? I have a W2 and an E wire that go into different screws on original but no seperate terminal...
C is actually a power wire; it provides power for some programmable thermostats. You don't have to connect it on the new thermostat; cover the end with electrical tape to avoid it causing a short. (If you keep that wire accessible, it will be nice for someone who wants to use another programmable thermostat. The ones which can talk to wireless networks require this wire.)
Do you have a heat pump? That is the only time a thermostat uses an E wire.
The W2 wire should go to AUX (third screw terminal from the left) and the E wire should go to E (second screw terminal from the left). See page 25 (27 on the pdf) of the Quick Installation manual for the RTHL3550. This manual is available from Honeywell at http://yourhome.honeywell.com/home/Products/Thermostats/Digital-Non-Programmable/RTHL3550D.htm .
I hope this helps.
Nov 03, 2013 | Heating & Cooling
Hooking up a new thermostat honeywell rth7600 from a honeywell t8411r. we hooked up the wires as shown in the installation manual- we have fan but no cold air blowing out or it feels like the heat is...
apparently who ever did the wiring installation did not use the Proper color coding when they did the install. Now you must trace the wiring to the appliance and wire accordingly.
Oct 10, 2013 | Honeywell Programmable Thermostat Heater
Where can I find a replacement for Honeywell T8411R thermostat?
The first thing to do is to look at what color wiring you have on the thermostat.
Most all thermostats can replace one another. You will most likely have to refer to the instruction manual on the new one to see where the wires go.
Best advice is to take detailed pictures of what you are currently using. Refer to the new thermostat instructions for how the wiring should go based on which ones you have available. Remember it will take up to 15 minutes for the A/C or heating to work with the new unit.
Also be sure to note if you have any little junctions between two wires to loop them. I had that on my old unit. Then I ran into a problem with the new unit, switched back as I was trying to figure it out and couldn't get the old one to work until I found a piece on the floor and added it back.
Feb 28, 2011 | Honeywell Programmable Thermostat Heater
Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Sep 26, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
444 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
