American standard heat pump 2 ton circuit board green led flashing on unit
  • 130 Answers
daddyo742001
  • 70 Answers
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Posted on Jun 28, 2009
SOURCE: Is there a system mismatch with an American
This must be a heat pump? Sometimes the unit can be more efficient with this combonation. What you are probably hearing is the reverse direction of the
refrigerant going back through the liquid line.
If in cooling sometimes you can hear a gurgling sound going through the expansion valve, sometimes
this is a sign of low refrigerant or the system is fine..
If you recently had the outdoor unit replaced and noise is an issue, check to see if the unit has isolation pads installed underneath the unit whether
it be on concrete slab or on brackets mounted to
house. Sometimes the new units come with compressor that has a jacket installed over it
Posted on Feb 14, 2010
Testimonial: "Thanks, I was told that the noise at the TRV valve on the air handler is liguid refrigerant (rattling noise) and that the systems are mismatched."
james3751
  • 614 Answers
SOURCE: LED on defrost control board is blinking 3 times
Does not initiate defrost on ots own. Loose sensor. If sensor is not loose replace defrost board and sensor. Russ
Posted on Mar 25, 2010
shastalaker7
  • 1515 Answers
SOURCE: American Standard Air conditioning unit Model 2AGB0036A1000AB
Hi I am sure this model number is correct and it is a 3 Ton unit.Normally when the breaker trips as soon as you reset it, the compressor is compromised. Happened to me yesterday on a 5 ton heat-pump. When this happens, what you can do if you are a handy type of man, is to prove this. I don't know if the is is a split system or a all in one package unit, doesn't matter. Get to the compressor compartment. Of course the power will be off.If you can see the run capacitor, take a screw driver and short across the terminals to discharge it, as it could have a small amount of juice in it, I doubt it. Anyway, remove the plastic cover to expose the terminals. They can be hard to remove sometimes, just use a screw driver to push the clips in. Wire colors should be black for common, yellow for start, and blue for run. Write down the order they were in. To be safe, tape the metal connectors so they wont touch metal when you turn the power back on. After you have done this, turn everything back on. If the breaker holds and everything else is on, fan and so on, this proves the compressor is probably shorted to ground. If this a/c is rather new, I would replace the compressor. If it is old, I would think about getting prices on a new unit. Just food for thought. Please let me know on the out come of this test, please. When a compressor shorts out, or locks up, it draws what is called locked rotor amps/LRA which could be from 49 on up, and your breaker can be 25, 30, 35 to 40 amps so it will trip. Keep me posted and do this test, it is very easy to do.
Sincerely,
Shastalaker7
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: UNIT: American
What or why is there a red blinking light on front of the unit
Posted on Jul 19, 2013
I have American standard heritage 11 heat pump with the coils inside btw it's a double wide I was wondering where the fuse might be located
There will be a box that the unit gets power from, either up on the roof or on the side of the home, the fuse or circuit breaker will be in there.
Jul 18, 2016 | American Standard Heating & Cooling
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
American standard heat pump will only work on emergency heat with fan turned on not auto but only works a little while then quits i can turn it off for about 20 min. and back on emergency heat with fan on...
How old is the unit? Heat pumps don't work when it's real cold, you know it's limits. If it's not real cold outside, then it may be low on gas or such and need a service call.
Nov 26, 2013 | American Standard Heating & Cooling
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Jan 02, 2011 | Heating & Cooling
My Amana asx 16 seer 4 ton system installed 3 years ago quit working. The alert light is flashing 6 times. What does this mean?
Hi if you are looking at the indoor unit and this is where you see this flashing light, remove the panel. The circuit board is where this led light is. You will also have a 3 to 5 amp fuse plugged into the board. Look for a chart on a panel door. It will be glued there. It will tell you what the problem is according to how many times it flashes. Could be several different safety switches. Make sure there is no door panel switch on the indoor unit, has if there is, the unit will not run after you remove the panel, it kills power to it. You may need to tape it down so you can have power to run it and check it out. Is the indoor unit a gas system or is it a 4 ton heat-pump? If you cant find what I have said, get back to me after checking these things and let me know . Check all breakers. Let me know if this is a package unit or a split, indoor and outdoor unit, or all in one. I will wait to hear back from you on this.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Jun 29, 2010 | Heating & Cooling
Heat pump not cooling after wiring damage repaired.
Do you have the model number? This would help find the code
Aug 10, 2009 | American Standard Heating & Cooling
We had a new American standard furnace and A/c unit installed. A 2 ton compressor and a 2 and a half ton A coil. The unit is not cooling the charge was checked and it is ok. Unit is on and blower working...
make sure orfice used was for two ton unit and correct refridgerant also make sure that the elect auk heat is not pulled in check the psi on out door unit should be close to 225 hi side and 70 suction if heat pump switch the reversing valve man by orange stat wire to make sure shifting hope this helps
Jul 06, 2009 | Heating & Cooling
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Coleman 15k will not come on
Here is the troubleshooting guide for your unit. Hope this helps.
TROUBLE SHOOTING GUIDE
TROUBLESHOOTING
Symptom Remedy
1. Remote does not turn on system
- Check and replace remote batteries if the display fades while
any button is activated or no display is present. - Point remote towards IR receiver during transmission. 2. System does not turn on, no green LED & no beep
- Check wiring. (see "installation instruction")
- Check modular cable to receiver.
- Check diagnostic LED status in the upper unit control box.
3. System does not turn on even when receiver green LED is on.
- Low or over voltage condition, check diagnostic LED status in the upper unit control box.
4. Fan runs but no cold air.
- Evaporator temperature sensor reaches low limit, defrost mode.
5. System runs continuously in the cool mode
- Remote was set for "I feel" mode and is left in a heated environment (sun etc.)
6. System runs continuously in the heat mode
- Remote was set for "I feel" mode and is left in a cool environment
1. Diagnostic LED (green)
(Note: Located on the control board in the upper unit control box.)
a) The LED is on when the 12VDC is adequate and communications are
present.
b) The LED is flashing fast and steady when in the freeze mode. Evaporator has frozen and the freeze proctection switch is engaged.
c) The LED is flashing slow and steady when the delay on break timer is
activated.
d) The LED is flashing 1 cycle on and off for one second with high or low
12VDC. Check the incoming 12VDC power for OK.
e) The LED is flashing 2 cycles on and off for one second with a
communication problem. Problem with the control board in the unit and the remote.
Hope this helps.
Jeff
Rate me Please!!!
Jul 29, 2008 | Coleman Mach 15 Air Conditioner
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
