Question about Pyle Am/fm/sd/usb/mp3/aux Receiver Bt Streaming Lcd Display [plr27mpbu]
Random problem in pyle car audio
I play from USB, when I click on random, it goes random. When I switch off the car and turn on again it does not remember random. How to make it remember random. It goes to the same song.
I am wiring a Pyle PLMRKT36WT. There are two power source wires. ACC and POWER B+. What is the difference between them and how should they be wired/switched.
didnt specify vehicle --acc is an accessory port or line which goes on and off with key --power b+ is constant power positive side of battery continue live
Jun 10, 2017 | Pyle Car Audio & Video
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
I could not get my Pyle player to play a dvd or even recognize my Ipod when I connected it to the usb
TRY PUSHING YOUR RESET BUTTON. THE PLAYER WONT DO TO THINGS AT ONCE. IT WONT PLAY A DVD WHILE PLAYING YOUR I POD
May 26, 2011 | Pyle PLDN70U Car DVD Player
I got a pyle 1800w amp and a 1500w kenwood subs but as i increase the volume in the headunit it goes on protect mode why the other problem i got is as increase the volume in the headunit the bass of the...
The protection modes in these units ****. Most new units have them. What I do is turn down settings on deck and turn up amp as much as possible. Then the protection won't turn on because you won't have to turn it up as high.
Sep 30, 2009 | Pyle PLA1200 Car Audio Amplifier
I cannot play DVDs without the parking brake engaged how do i bypass this?
I ran across of alot of lcd head units that requiers the parking brake wire connected so it will show the video, (usually just audio if parking brake not on). But if you connect that wire to a proper ground (screen always on) or a grounded switch so you can control it maually (turn it on or off when you choose)
May 30, 2009 | Pyle PLD52MU Car DVD Player
Ipod connectivity
Don't use the USB port. Use the Aux input
Oct 17, 2008 | Pyle Car Audio & Video
Pyle Am/fm/sd/usb/mp3/aux Receiver Bt Streaming Lcd Display [plr27mpbu] Logo
62 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
