Question about Frigidaire Dishwashers
We have a FDB2410LDSI sometimes it leaks from underneath. What do I need to do to repair it?
  • 34 Answers
1 - have you checked if when the machine is operating if the tubes are leaking or if the joint between the out tube and the sink is leaking?
2 - Be careful, tuis appliance works with dangerous voltage on almost each element inside. Disconnect the plug before operating insite the device.
For the wather: close the tap and eventually remove the tubes. the wather can come out of both.
Now pull out the dishwasher out of the counter. sometimes is secured with some screws on the sides: open the door and look on the top, right and left side.
I can't find a service manual for this model. So try to open de rear panel (it's normally fixed with some screw, for example some secure torx). take a look inside if all the tubes are securely fixed and if there is a place that has some depot on it.
you can use a cable clamp to secure the tubes.
Posted on May 09, 2014
Leaking water underneath in center of washer. Rubbing noise (metal to metal) when washer tub is turning.
Dear Kathy,
I hope you have 2 problems, otherwise if it is one, it may mean a new machine for you.
Lets do the grinding first.
These machines have a drum that spins.
If they wear out, and all things do, sometimes a part or two is all that is needed to repair it.
However, if the "wearing-out-part" is the spinning tank itself, and it wears all the way through, you will need a different machine, it will cost more to fix it that it is worth.
Someone will need to take it apart, or put the whole thing up high in the air on a pedestal, and look underneath it whilst it is running to locate the source of the "grinding". They will need 1) knowledge, and 2) a strong light..
The leak, if it is not the spinning tank, could be a hose or connection, which the repair person will find when they look up underneath it.
God bless your efforts.
Apr 08, 2016 | Washing Machines
Water Leaks Underneath
You really need too look underneath and see where water is coming from that means raising the machine off floor washing machine quite heavy so need to know what your doing
Nov 09, 2015 | Whirlpool WFW9050XW Washer Front Load...
Maytag dishwasher leak
If it's leaking from the door, a new gasket may fix this. If it's leaking from the pump, the seal is worn out, and the repair may be too costly or difficult. If the unit is 5 years old, consider a replacement.
Aug 29, 2015 | Maytag Dishwashers
Program selector is not working properly
Only you will know for sure. How Old? What condition? Depends on cost of repair.
Several simple problems. It needs a service for sure
Apr 02, 2015 | Washing Machines
Maytag Centennial washer leaking oil underneath, do I need a tech or are they user friendly?
Oil may be coming from transmission seal leak? can possibly be taken care of with some serious sealent? its a tiny slot that covers it and sometimes goes bad
Oct 13, 2014 | Maytag Washing Machines
Sienna 2001 oil leak Problem. 230,000 miles oil is leaking from underneath the engine a lot.
a leak under the motor can be from many places, first check the top parts,, most the time its a valve cover leaking, sometimes it just needs to be tightened from many miles of vibration, they loosen up, if that checks out ok, try underneath ,, the oil pan gasket and the oil filter seal ,
Aug 05, 2011 | 2001 Toyota Sienna
Washing machine leaking from underneath
Check the hoses underneath drum. Sometimes the get disconnected. If still okay? I would take the front panel off and run the machine to see where its leaking from.
Apr 03, 2011 | Washing Machines
How do you repair a heater core in a1998 gmc jimmy
You replace them, generally requires getting up underneath the dashboard and sometimes removing the dashboard. You can try one of those radiator leak repair goops which are supposed to fix leaks, but I have yet to see one actually work. You dump these into a warm radiator, they glop around the leak and seal it, according to the packaging. Any car parts store will have a host of these sitting on the shelf.
If the core is leaking you can just disconnect the heater hoses which connect to it and put a piece of tubing between them to maintain flow. About half the Jeeps I have ever seen have this method of repair, but it tends to be a bit cold in the winter.
Jul 22, 2010 | 1998 GMC Jimmy
Leaks water underneath ..repair man said there was pin hole in hose underneath and needed new hose..are they over 100 dol to replace? Doest seem a tiny pin hole could cause that much water to flood out.
If you can locate the pin hole then when the machine is dry block the pin hole by putting araldite glue paste and let it settle for sometime. It should solve your problem.
Mar 11, 2010 | Kenmore HE2 Plus Front Load Washer
Fisher and Paykel Washer leaking water
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Oct 03, 2008 | Washing Machines
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
