Question about Toshiba Office Equipment & Supplies
I have an e-studio 45 that prints black lines on the bottom of the copies the more copies the thicker and darker the linesI understand this machine is obsolete but there is no money in the budget for a new one, what can be done to fix this issue?e?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
Try to clean drum unit .
Posted on Jul 06, 2014
zeusfaber
  • 247 Answers
SOURCE: Black lines on scanned copies
Try this. Lift the lid to expose the top glass. To the left of the main glass panel, you will see a narrow glass strip. Clean this strip using a soft cloth or sponge moistened with a nonabrasive glass cleaner, then dry it off with a dry chaois cloth or cellulose sponge. A.
Posted on Apr 04, 2007
gwbm
  • 353 Answers
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
BigdaddyTDW
  • 62 Answers
SOURCE: 2 vertical, parallel, black, lines print on copy
Sounds like it could be bad cartridge or scanner. Try replacing cartridge first cause this is pretty easy to do and is alot cheaper.
Posted on Feb 12, 2009
SOURCE: My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Posted on May 01, 2009
  • 20 Answers
SOURCE: HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Posted on Jul 07, 2009
How to get the black darker
You can use Paint on your computer to modify it. If not it just might be the type of printer. See if you can buy darker ink at another store. If not your pretty much stuck like that. You can also go to copy stores or most major stores to get stuff copied for free or cost....
Windows 7 XP Security Center
Jan 29, 2014 | HP Designjet 5500 InkJet Printer
Is there a way to make the print darker on a Toshiba 352?
your ink magazine(!) might be old or used much. Try to change it.. and place a new one
Sep 15, 2012 | Toshiba e-STUDIO 352 Black and White...
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
E-studio 45 is developing faint print generally, with some areas lighter in a mottled pattern. It has a new toner cartridge. Serviceman says he is not sure of the cause. He cleaned the inside, after...
I would call the service company and ask for another tech to look at the problem..... Yes the problem could be caused by the developer. I could also, be caused by the opc drum or the charge roller... Good Luck
Jun 11, 2010 | Toshiba e-Studio 45 Black and White Copier
I have a toshiba e-studio 35. When copying through the feeder a line appears on the right side of the copy. Techs dont know how to fix it.
"Normally" that is a simple problem. If it copies clean when you lay your original on the glass......but when using the Automatic Document Feeder (ADF) the copy has a black line then it is clearly something in the ADF scanner. Some machines use a strip of glass that is next to the large glass to scan originals when using the ADF. That strip of glass has to be clean top and bottom. Some models use a scanner in the actual ADF. Either way if it copies fine from the glass, the rest of the copier is eliminated from being the cause.
Is your machine under maintenence contract? Then I would keep calling them until they FIX it!
Oct 22, 2009 | Toshiba e-Studio 350 Copier
ESTUDIO 45 SPILLING DEVELOPER. BAD COPY QUALITY
Since developer material is spilling, so the developer material is less, thus blur print will occur. The fastest way to solve this issue is to replace a whole new developer unit with new developer material, but this might be quite costly. Otherwise, u need to ask technician to check your machine. Then only can confirm the defects.
Jul 29, 2009 | Toshiba e-Studio 232 Black and White...
COPY QUALITY
Voids are most often caused by lack of sufficient developer, which needs to be changed by a technician. developer has metal beads in it to draw the toner and make a full (dense) copy or print. these beads wear out or "dump" which initially cause gritty prints, then washed out prints. hope this helps.
Jul 09, 2009 | Toshiba e-Studio 45 Black and White Copier
HP Photosmart C7180 All-In-One
Hi try coping a document from the machine and see if the copy comes out with these lines. If it does then the machine scanner unit is faulty and will need replacing. If not then the likely thing is that the printer device drivers are incorrect or faulty. reinstall the drivers or download a up to date driver from hp.com for the other printing darker try changing the graphic processor mode in the driver. Goto printers and faxes right hand click on the printer icon and select properties.
Once in properties select the advanced tab at the top of the windows within this tab at the bottom select print processor. Once in there choose another graphic mode OK close and test if no improvement select a different one and so on until improvement is achieved. if no improvement then reinstall the drivers if you haven't already.
Hope this helps
Thanks J
Nov 29, 2007 | HP Photosmart C7180 All-In-One InkJet...
Blackness on paper, image OK
Hello ace002 and LauraJ. I already sent a long winded response but i dont know if it went thru. The drum 4 your machine is good for 55 k at best. Canon is great on their projected yields those estimates can be skewed by age(time) Typical drum failure results in black lines and background. I know I did not fix you problem but at least you are armed with knowledge in case you need on site service. Best of luck........Spinal
Oct 16, 2007 | Canon (6981A002AA) for imagerunner 2200,...
32 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
