Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Why is refrigerator too cold, amana afi2538aes?
  • 42 Answers
If your 'food' is too cold, you may have the temp. controls set too high, or the condenser coils might be dirty,
Depending on the location of the food that is too cold, if it's some and not all, you may have the 'some' too close to upper left air inlet.
Most likely, the temp is set too high:
Set the refrigerator control to next higher number by pressing the + (plus) button to the next higher number.
** Do not change the control more than one degree at a time. Allow temperature to stabilize for 24 hours before making a new temperature adjustment. **
If it's not the temp, them clean your condenser coils:
Remove the base grill to access inside. Use a vacuum cleaner hose nozzle and vacuum all dust/debris. The condenser fan outlet grille
should be vacuumed with a brush attachment on your vacuum.
Here's a video:
Posted on May 08, 2014
  • 45 Answers
Thermostat gone. Needs to be replaced.
Testimonial: "I ended up replacing the thermister located behind the light bulb. Temperature is now under control. Thanks"
What causes water to come out from rt side of my amana AFI12538AES4
did you check to see if the hose that runs down to the pan at bottom of fridge is blocked
Feb 14, 2013 | Amana AFI2538A Bottom Freezer French Door...
Not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Amana AFI2538A Bottom Freezer French Door...
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
I have an Amana AFI2538AEW. Most of my Vegatables in the crispers are freezing and a bottle of milk in the back is frozen also on the shelf. Can you help me?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 30, 2011 | Amana AFI2538AE (25.6 cu. ft.) Bottom...
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Why is food freezing in the top comparment
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 03, 2011 | Amana AFI2538A Bottom Freezer French Door...
Our Amana AF12538 AE Refrigerator is causing the vegetables in the vegetable bin to freeze. What could cause this? the Units is only 2 years old.
Refrigerator temperature control set too cold or faulty Fresh Food thermistor.
Adjust refrigerator temperature control or check thermistor.
1 Refrigerator section too cold
2 Refrigerator airflow not properly adjusted
3 Check air flow.
Just too much information for this page. If you would like the long version please let me know. I am a Technician and have the tools and the answers if you would like my assistance. I will go out of my way to help you and would rather tell you this first so please do not rate unless I assist you Thanks, Sea Breeze
Dec 30, 2010 | Amana AFI2538AE
Refigerator has no cold air freezer works good
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 21, 2010 | Amana AFI2538A Bottom Freezer French Door...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
97 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
