Question about Bosch Kitchen Ranges
Looking for bosch grease filter
Need to buy a set of bosch grease filter
  • Bosch Master
  • 3,497 Answers
Is that a carbon filter that is circular that fits over just the fan. I think I saw this at Better electrical. this web site may help find your nearest Bosch dealer http://www.bosch-home.com.au/dealer-locator.html. If you are not in Australia look for the Bosch web site in your country and look for dealer locator link.
Posted on May 08, 2014
Bosch range hood is making noise but not sucking air. DKE 645 / DKE 945. Any advice welcomed.
There's a backdraft damper located in the ductwork either right at the fan, or where it exits the building. The grease filters could be plugged, or the fan itself could be plugged with grease also. If vented to the outdoors, the vent could be blocked by birds or other critters. Does the fan sound 'normal'?
May 01, 2017 | Bosch Kitchen Ranges
What is E22 error message on Bosch dishwasher
Hi Darlene, The link below is a bosh dishwasher error code AND how to fix, I hope this helped..........CHEERS..
Bosch Dishwasher Error Code E22
Fault Condition: Residual water in sump
Repair or Check: Check for a blocked pump, a dirty filter, or grease build up.
Parts Required: Pump or clean filter
Bosch Dishwasher Error Codes How To Clear What To Check
Apr 24, 2016 | Bosch Dishwashers
What grease is used in a Bosch Hammer drill PSB 400-2?
Contact Bosch at 1-800-241-3848. Parts and a breakdown can be found at toolpartsdirect.com also.
Jan 03, 2013 | Drills
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
Maintenance on a bosch pbh 2200 re sds, do i need to put oil or grease anywere in the drill?
The Bosch hammers all use a special grease for the hammering mechanisms. You should be able to buy a small tube similar to the size of a toothpaste tube, from a Bosch dealer or online. The part number is 1615430014. Here is what it looks like.
http://www.ereplacementparts.com/grease-tube-p-768150.html
Jul 16, 2011 | Garden
Bosch Nexxt wtmc6500uc dryer. We receive an e01 error with every load and now cannot run the dryer at all. The vent is less than 5' with one bend, we clean the filter with every load, we've replaced the...
This was a previous post, but it may work for you.
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try.
Feb 12, 2011 | Bosch Nexxt WTMC 6500 Gas Dryer
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
We have cleaned everything--the vent clear out of the house; everything and yet the E001 buzzer keeps going off saying the lint filter is not clean--it is. We are so disappointed in this dryer! Can you...
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Dec 01, 2010 | Bosch WTMC3510UC Gas Dryer
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Bosch demolition hammer oozing grease/oil.
Look around there for some O rings we have had this same problem with some of our Bosch hammer drills, and they usually replace a set of seals around the nose of the tool
Jul 05, 2009 | Bosch Hammering
Kitchen Ranges Logo
157 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
