Question about Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone ba
  • Gail Johnson
    Gail Johnson May 10, 2014
    Thank you.It was the pulley and the belt was broken.I ordered them .Hope this works.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Yes it could have gone bad. Also you might be missing one of the 120 volt legs that the dryer needs to run. Try turning the Dryer circuit breaker all the way off then back on and see if it will work. It also could be that the belt that goes around the drum might have broken or come off the motor. If you can, open the top of the dryer and look for the belt to see if it is OK. Best of luck.
Posted on May 08, 2014
2 Suggested Answers
sonicboomele
  • 1557 Answers
SOURCE: maytag model# MED5700TQ0 Suddenly will not start.
i would start with the door latch if its broken the dryer will think its door is open and wont turn on
Posted on Apr 21, 2010
Dishwasher Asko 1986 suddenly stopped working
Also is mainly a control board's
Did you have a power outage or power surge?
Need model
Oct 08, 2016 | Asko Dishwashers
Maytag mod. #med5700tq0 elec. dryer runs, inconsistent heat, high heat two days ago, little heat a few hours ago, some heat an hour ago, no heat now. Where is the best place to start?
It sounds clogged up to me. Take the exhaust hose off the wall and try it first. Another thing that happens with Maytags is that the motor shaft will **** out the center of the plastic blower and even though the motor is turning, little or no air is moving through the machine, so the high limit thermo turns the heat off
Oct 18, 2011 | Maytag MED5700TQ Electric Dryer
Maytag dryer (Model# MED5700TQ0) will not start. Light inside works, but the tumbler won't turn. the door is completely shut.
Hi and welcome to FixYa. I am Kelly
Open the door and grab one of the baffles. Check to see if there is major resistance when you try to rotate the drum. No major resistance = a broken drive belt
A broken drive belt will also trip the belt safety switch by the motor and will not allow the motor to start.
The drive belt is item 26 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161471
Please check the door switch for a click when you just open or close the door. Within about 1 inch of closed usually you will hear an audible click. You said the light works so I doubt the door switch is the problem... (it still can be the problem though) 1/2 of the switch is for light control the other half for drying control.
The other suspects can be
1. The start switch
2. Timer control
3. Motor control switch
ONE more thing to check is go to the main circuit breaker panel and physically push the dryer CB to OFF then back on. After doing this try to start the dryer. Sometimes ONE of the 2 CB's trips for unknown reasons.
Finally if the dryer vent system was restricted and the the dryer got very hot (309 Deg) the thermal fuse on the side of the internal rear duct housing will also shut off the dryer and it will not start.
Item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5161471&diagram_id=907130#d907130
http://www.appliancepartspros.com/part_details.aspx?part_id=3094244
Before you return the dryer to service... vacuum everything including all ducting internal and external to the dryer. Do not forget the thru the wall vent flapper where it exits the outside wall.
Thanks for using FixYa
Kelly
Apr 25, 2010 | Maytag MED5700TQ Electric Dryer
Maytag model# MED5700TQ0 Suddenly will not start. Light inside works, so electric power is on. Could the start button have gone bad?
Apr 21, 2010 | Maytag MED5700TQ Electric Dryer
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde5500ayw dryer had an oversurge of power earlier, now dryer display is dead but light inside is on. Is there a fuse in dryer?
could be one on the control board, but I will bet if you had an electrical surge theres more than just a fuse gone
Oct 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer won't start
Are you getting any power to unit? The power supply most likely overheated and burned out a capacitor. It is possible that the relay may have gone bad to.
Jun 23, 2009 | Maytag PYE2300AY Electric Dryer
No power
First place to check is the door switch...it works the light inside, but it is also a safety switch... the door has to be closed for the dryer to recieve power... if the switch isn't "clicking" when you press it by hand or with the door shut, then it's most likely the switch. try this first... let me know what you find out..
May 28, 2009 | Maytag Dryers
My Maytag Neptune dryer suddenly quit working. The light comes on inside, but it won't start.
This could be several easy fixes. Check to see if the door switch is working if it is not clicking when pushed this could be the issue. try resetting the breaker, if it's not getting both legs of the 240v it won't start. or the start button could be defective. This is where I would start (and most of the time finish) looking. With some common tools and an ohm meter you should be able to find the problem.
Jan 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
TUMBLE DRYER SUDDENLY STOPPED WORKING. ALL LIGHTS FULLY FUNCTIONAL BUT THE PROGRAM WON'T START WHEN START BUTTON PUSHED. RED LIGHT IS FLASHING ON START BUTTON. mODEL WTE6920
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Sep 15, 2008 | Dryers
Maytag Bravos 7.0 Cu. Ft. Electric Dryer Logo
106 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
