Question about Maytag Kitchen Ranges
3850W1W094B bolts I bought this used and am trying to find the right bolts to mount it under my cabinet. Various manuals call for 1/4-20 or 1/4-28 bolts neither of which seem to fit. How can I find out the authoritative bolt?
    Problem Solver:
  • 10 Answers
Check on line for an owners manual.
Posted on May 10, 2014
I need to replace a wall mounted microwave oven. It needs to mount only to the back plate - there is no access to mounting holes in the top. I have replaced this oven once before, but now I cannot find a...
I just replaced one of those myself. New one had totally different back plate which had to be replaced. Both new and old ones were bolted to cabinet above.
Oct 29, 2013 | GE JEB1095 Electric Single Oven
Tip
How to replace the bulb of a microwave oven
Replacing a Built-in Microwave Oven
  1. Step 1 Locate the cabinet above the built-in microwavemag-glass_10x10.gif oven. Find two screwed-in bolts. Unscrew the bolts while someone holds the microwave steady.
  2. Step 2 Unplug the electrical cord from the cabinet above and snake the wire down the hole towards the microwave oven. Continue having someone hold the microwave steady.
  3. Step 3 Roll microwave to left or right to set it free from the mounting bracket in the back. The microwave oven should now be unlocked from its position and can be removed completely from the area.
  4. Step 4 Install the mounting bracket on the new microwave that was included in the package.
  5. Step 5 Snake the electrical cord of the new microwave through the hole in the above cabinet. Plug in the electrical cord.
  6. Step 6 Lift the microwave and rest it to line up with the existing mounting plate on the wall. Roll it until the microwave is locked in place.
  7. Step 7 Use a screwdriver or electric drill to screw in bolts above cabinet into the microwave mounting bracket. This will keep the microwave securely and tightly in place. Your new microwave is ready to use.
on Apr 04, 2010 | Microwave Ovens
I have no way to connect to the granite counter top. Can it be mounted to the side cabinets?
Need prefix for model number. Need complete model number. I believe that the numbers that you have given are stock numbers from your user manual. Kenmore can be several different manufacturers. Some brands have kits to mount unit from the sides using brackets at the top. If stainless steel tub, look for removable plastic caps on the right and left sides of unit. These holes would be used for installing bolts into cabinet. If plastic tub and no kits are available holes can be drilled into sides to secure unit to cabinet. As long as heads of bolts(screws) are flush to allow door closing, unit will not leak because of tub(door gasket.
Feb 15, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
What size bolts do i need in order to mount it under the cabinet. the bolt that comes from the cabinet into the micro
mcdevito75 here, Best Bet bring the mounting bracket and bolts recieved with the unit to your local hardware store. they will give you the correct bolts need to mount undera cabinet.
Jun 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
A friend bought me a cannondale airspeed maximum pump i am trying to mount to my bike it has a snap type mount? with screw holes matching the bottle mounts how does this work? pump will not be centered on...
The pump mount is installed under the bottle cage, if you have one, using the same bolts. Sometimes longer bolts are required.
The pump snaps into its mount besides the bottle cage, on the left or right side.
Nov 04, 2009 | Cycling
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
Removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Aug 27, 2008 | Microwave Ovens
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
TV surface swival security mounts
Madam, in most cases the swivel mounts are fixed at the base of the TVs with a pair of Bolts / Screws and Nuts.
Please check.
Jan 29, 2008 | Televison & Video
Kitchen Ranges Logo
48 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
