Cnet com How can I have access or (a formula) to be able to open a cable with a four number's combination? This is a combination Master cable lock. Master lock has no help for this problem plus a locksmith.
  • 130 Answers
Http://www.youtube.com/watch?v=w4wkCcsWs4c
Posted on May 09, 2014
How to reset combination
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
the door and conceal your combination
7. Close the shutter door
Sep 03, 2014 | Master Lock 5400d: Portable Select Access...
How do you open a master lock model 5400d if you forgot the combination
It would appear that you made a mistake in setting your new combination on your Master Lock 5400d and did not register the combination at Masterlockvault.com. The only way to open your lock is by using the correct combination. There is no other way. Most mistakes are normally one or two digits out, so you may wish to try variations on what you thought you set.
Apart from that you can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
Jul 14, 2011 | Master Lock 5400d: Portable Select Access...
I have a master lock its a lockbox model 5400d i forgot the combination and my car keys are in it
You have forgotten the combination on your Master Lock 5400d and did it appears that you did not register the combination at Masterlockvault.com. The only way to open your lock is by using the correct combination. There is no other way. Most mistakes are normally one or two digits out, so you may wish to try variations on what you thought you set.
Apart from that you can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything as is currently the case. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
How do I reset the combination?
Open the lock with the existing combination. Inside the outer panel, you will see a small lever that will push to the right, and **** in an upward position. With the lever cocked in this "learn" position, turn each wheel to line up the number you desire with the scribed line. Once all four wheels are parked on your chosen combination, flip the lever back into its "home" positon. Test the new combination a few times (and record it somewhere safe), before you close the lock up.
Dec 31, 2010 | Master Lock 5400d: Portable Select Access...
How can i reset my master lock
You can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination
Oct 07, 2010 | Master Lock 5400d: Portable Select Access...
I've had a masterlock 5400d master lock for half a year and I forgot the password and it contains a special key.
You can either try every possible combination or you will need to contact the manufacturer. But they cannot assist you if the lock does not have a serial number (they recently stopped applying serial numbers for greater security) and they will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
Sep 21, 2010 | Master Lock 5400d: Portable Select Access...
My 5400D is open and I forgot the four digit code can you help me re-set it???
Aug 13, 2010 | Master Lock 5400d: Portable Select Access...
I lost the combination and can't open it
The only way to open your lock is by using the correct combination: there is no other way.
Jul 07, 2010 | Master Lock 5400d: Portable Select Access...
I lost my lock combination for a light blue master lock is there any way to get it the serial number is 8000109
You can either try every possible combination or you will need to contact the manufacturer. They will not assist if the lock is already secured to anything. There are a number of other hurdles as well, click here for details. Given that they state that you will have to wait four to six weeks for an answer, it's going to be far quicker to just try every possible combination.
May 08, 2010 | Master Lock 5400d: Portable Select Access...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
