Windowsupdate 80070216 wont let me download any updates and this error code comes up...anything I can do to fix this.
How do I fix WindowsUpdate_8024A000 error in Vista 64 Toshiba Satellite M305-S4848?
Are you on 1TB SSD? Wow! And still on Vista? Have you tried to Google with your update error?
Apr 14, 2015 | Toshiba Computers & Internet
How to fix windows update 80070216
Machine is infected with a rootkit or a virus.
Windows errors can occur for a number of reasons, including programs not installing or uninstalling properly, malware, system conflicts, Active X errors, and the most common, registry errors. PC registry errors occur over time due to the constant writing, editing and deleting of information from your computer's registry over time as programs are installed, modified and removed.
Many malware and spyware programs can also cause unwanted changes to your PC registry, which leads to the errors and reduced PC performance you are likely experiencing. In some cases, registry errors can be occurring without you noticing. They are still harmful and should be fixed regularly.
Download and run Kaspersky TDSSKiller, then download and run Combofix. These two tools will clean-up your machine. The links to download these applications are provided below.
Windows Update should work after that.
Combofix Download
Sep 09, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Windows Update Error 80070216
http://answers.microsoft.com/en-us/windows/forum/all/microsoft-updates-not-installing-error-codes/8a046630-b9b8-4191-aac6-9075ac658d6c
Apr 18, 2014 | Microsoft Windows 7 Professional for PC
Error code 80080005
Is your windows updates disabled? Is your anti virus up to date? Do you have a Malware program, updated? If you do not have MALWAREBYTES download and install :http://www.filehippo.com/download_malwarebytes_anti_malware/ Run a FULL SCAN, may take hours, depends on HDD size. Delete ALL RESULTS. I don't know your OS? Vista? win7? 32? 64? Her is a standalone windows update for both 32/64:
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x86.exe or
http://download.windowsupdate.com/v7/windowsupdate/redist/standalone/WindowsUpdateAgent30-x64.exe
Nov 19, 2012 | HP TouchSmart Computers & Internet
How to fix this problem
http://www.vistaheads.com/forums/microsoft-public-windowsupdate/322548-error-646-a.html read that page, has all the info you need on how to get info and the official MS page to fix it.
Should be able to help you properly
Jan 03, 2010 | Microsoft Windows Vista Home Premium with...
I keep getting error code 0x80080005 when trying to download service pack pack 2 on vista and error code 80080005 when trying to run windows update. can you help?
you can download it from softpedia or dozens of places if you google it download it els where and install it that way i see alot of users have this issue i would also make sure your time date and time zone are correct if you still cant install it from the end user installer . *****http://www.softpedia.com/progDownload/Windows-Vista-Service-Pack-2-Download-112640.html here is the link i would try *****right click your my computer go to properties and find out if you have 64bit windows if so you need to download the x64 version if not x86 is for you food luck
Sep 20, 2009 | Computers & Internet
Can't recognize new nvida video card and ram automatic updates dont work error message 0x8DDD0007
Found this solution, may apply to you:
Thanks to a gentleman by the name of Igor Franchuk, he has found the
fix to this problem, and it so easy, it makes me mad.
Here is what we sent to me:
" I've encountered the same problem as you did today. When searching
the
Internet for the same error in hope for a ready solution in
some discussion forum I surfed over quite a few responses and none
of them were solutions.
After giving up I came up with a solution of our problem. It seems
like there was actually a mistake in the previous versions of
windows update.
After disassembling wuweb.dll that is responsible for webControl
update ActiveX object that is actually handling web based updates
I discovered the place where reboot required message is generated.
After looking in around the code I found that the condition
the message is generated is the presence or absence of
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto
Update\RebootRequired
key.
If the key exists - the message is generated by that brand new v5
update and it fails to work further causing [Error number:
0x8DDD0007].
I assume this key was set up in my registry long ago by the when the
old automatic
update (taskbar version) was uploading a new software and failing to
install it.
The solution then is simple remove the key
so there would be only
Update
key without RebootRequired entry.
REGEDIT4
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto
Update\RebootRequired]
After I removed the key RebootRequired v5 update started to work
happily, and installed a new version of wuauclt.exe
It worked for me wonderfully, and I feel a lot better about sp2. Hope
this helps those in need!
Jul 04, 2009 | E-Machines T3065 PC Desktop
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
