Question about Surco U4050 Urban Rack Silver 40 x 50 Cargo Rack Ford Escape 2008-201
Can't find the coolant temp sensor on my 2011 ford escape 2.5
  • 108 Answers
Look for it around the thermostat housing and our on the side of your engine block usly the left side .
Posted on May 08, 2014
Can someone help me on locating my c?oling fan switch on my 2003 ford escape.
Cooling fan switch ? The cooling fans on your vehicle are computer controlled . Relay's energized by PCM - engine computer . Coolant temp sensor is a input to the PCM ,when the temp. reaches 212 degress the PCM will energize the low speed fan relay ,if temp reaches 250 degress the PCM will energize the high speed cooling fan relay . Hooking up a scan tool an checking coolant temp. sensor data to the PCM and checking control from the PCM ( energizings relay's ) Is how to diagnose this . Not replacing parts and hope you fix the problem . Your best bet take it to a qualified repair shop.
Aug 13, 2017 | Ford Cars & Trucks
2003 FORD ESCAPE, COOLANT LIGHT WAS GOING OFF AND ON SO CHANGED DEGAS BOTTLE NOW COOLANT LIGHT STAYS ON WONT GO OFF. SMELLS LIKE IT MAYBE BURNING A LITTLE HOT BUT GAUGE STAYS NORMAL
perhaps if you bought a repair manual it would show you exactly what you need to do and where to look for the part .it screws into the block somewhere close to the upper radiator hose .
Jul 28, 2015 | 2003 Ford Escape
Hola buenas tardes tengo un problema con mi ford escape 2009 motor 3.0 que las ventiladoras de enfriamiento se me an quedado directac y no hacen sus ciclos de parar cuando el motor esta frio si no que...
Necesitas un sensor de enfriamiento del ventilador. Est? ubicado en el radiador.
You need a Fan Cooling Sensor. It is located in the radiator.
2005 Ford Escape radiator cooling fan repair. - YouTube
? 3:19
https://www.youtube.com/watch?v=3Sk5g4PGVWs
Sep 24, 2014 - Uploaded by hufhuffy
2005 Ford Escape cooling fan problems ,cooling temp sensor auxiliary fan control unit ,radiator fan switch ...
2009 Ford Escape Hybrid radiator cooling fan - YouTube
? 1:42
https://www.youtube.com/watch?v=tRdrV825xak
Mar 8, 2017 - Uploaded by stevenofpa
00243 2009 Ford Escape Hybrid radiator cooling fan - This video shows the engine cooling fan radiator fan ...
2008 Ford Escape Cooling Fans: Both Aux and Main Cooling Fans ...
https://www.2carpros.com/questions/2008-ford-escape-cooling-fans Jun 17, 2014 - I have replaced the Main cooling fan relay but didn't help. Not sure if there is ... 2002 Ford Escape Coolant Overflow Bottle Replacement.
2009 Ford Escape Cooling Sensors, Switches & Relays - CARiD.com
https://www.carid.com > ... > Ford > Escape Results 1 - 21 of 21 - Ford Escape Replacement Engine Cooling Parts - 2009 ... Ford Escape 2009, Coolant Temperature Sensor Connector by Standard®. 2009 ford escape replace cooling fan sensor Google Search
Oct 28, 2017 | 2003 Ford Escape
It should be on or near the Thermostat Housing!
Mar 28, 2013 | 2003 Ford Escape
I have a 2001 Ford Escape. The warning light for the rad comes on after the truck has run for 10 or 15 minutes - have checked all the levels and everything is good. Any ideas?
You may have a bad sensor in the resevior. You can try tapping on the resevior and see if sensor comes free and light stays off. The coolant level sensor or collant temp sensor could be bad.
Oct 28, 2010 | 2001 Ford Escape
Would a temp relay switch cause my 2001 escape not to start when hot
yes a coolant tempurature sensor could cause this you need to get somone to check the resistance of the sensor when hot and see if it corresponds with the correct readings
Aug 02, 2009 | 2001 Ford Escape
Rough start on 2001 escape
how about a simple tune-up?  Plugs and filters.
Mar 28, 2009 | 2001 Ford Escape
Surco U4050 Urban Rack Silver 40 x 50 Cargo Rack Ford Escape 2008-201 Logo
Top Surco Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Surco Cycling Expert? Answer questions, earn points and help others
