Question about NRS Hoveround MPV 5 - Used Power Wheelchair
When something goes shear through my tire; can that be patched up? Would I need to get a new tire if something causes a big enough hole? How are tire holes patched anyway? bryanflake1984| http://w
Tire
  • 108 Answers
Do you have solid tires or inflatable tires. If they our inflatable tires and the hole is not too big they can hot patch them at a tire shop most of the time for free. If its a solid rubber tire and you have taken a big chuck out of it you will have to get a new. But I am thinking you have an inflatable tire. take it too the tire shop and see what they can do.
Posted on May 08, 2014
How do I replace centering pin for shifter.
I am sure the pin sheared, that is why the shifter is not center. Push the shifter back to original position so that the hole would line up( using little force) Knock out sheared pin and replace with new one.
Regards
Phillip
Mar 26, 2015 | 2005 Harley Davidson XL 1200 C Sportster...
Tip
Flat tires
If you have a flat tire before you go to the trouble of taking the tire off the vehicle buy and keep a tire repair kit for tubless tires. If you get a flat, jack up vehicle and find problem with tire. Ninety percent of the time it is a nail in the tire. With tire still on the vehicle pull out nail and follow instructions to put patch in. ( ex. pull nail out. put glue on tool supplied. place in hole. put patch on tool and dunk in glue. Insert patch into hole and twist to insert patch. Cut off excess patch. Your done. Inflate tire. ) This saves you time and money and is as good a fix as you will get at a garage. Good Luck
on Dec 11, 2009 | Ford F-150 Cars & Trucks
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Flat tire
There are several causes of a flat:
You may have a puncture. If you've a large tub which can fit the tire, submerge it into the tub and look for bubbles (signifies the source of the leak). else you can pour water over the tire and look (closely) for signed of bubbles forming.
  1. You can patch it (which tire dealers frown upon since they'd recommend that you purchase another tire right away) if you're only using it for short trips, or
  2. you can do what dealers recommend and purchase new tires (they usually recommend purchasing in pairs of 2 or 4 to ensure even grip on both sides).
  3. if you're halfway during a trip, you may be interested in one of those tire foam products which temporarily seals the leak till your next repair
Or you may have driven over something hard (e.g. pot holes) and bent your rims. This may also cause tires to leak and eventually run flat. If that's the case, I wouldn't recommend bending it back unless the rims has sentimental value (assuming you're running OEM rims) - I'd say it's time for a new rim replacement (or even a set of new aftermarket rims) ;-)
Aug 15, 2010 | 2004 Hyundai Santa Fe
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
Ryobi ry60514 tines won't turn
there are shear bolts that hold the tines on. they are designed to snap when u hit something big such as a big rock or pipe or something like that. they are designed to snap at so much pounds of pressure so u dont break any gears or gearshafts. a lot of times people dont realize this and put regular screws or bolts in it and run it. when they hit something they ussually snap the gearshaft inside the tiller. i have replaced this on my fathers tiller cause he did the same thing. so either u might need to put new shear bolts in or if u had a regular bolt in u probably snapped a gear shaft or a gear.
Nov 23, 2008 | Ryobi Cultivator
How to repair a flat tire?
hi!
to find the hole, try to fill the tire with air, and put it on a shallow water were it's enough for you to see the bumbles that come out from the tire.
to repair a flat tire, take out the interior of tire and if you happen to see the location of the hole try to find an unused rubber and cover the hole with that rubber and glue it with a quick drying glue... (this is a non-professional work)
Oct 29, 2008 | Bell Sports #1002016 26" Mountain Bike...
Fixing a flat tire
Any bike shop will have patch equipment. You need to deflate the tire and remove it from the wheel. See if there is a tube inside the tire. If so, the fix is easy: either purchase a new tube for the tire, or get a patch. Use modelling glue on the patch then press it continually on the hole on the tire for about five minutes until it is dry. Afterwards, re-insert the tube into the tire, reattach the tire to the rim and pump it back up
Jul 13, 2007 | Kolcraft Jeep Liberty Limited Urban...
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
175 people viewed this question
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
