Question about Dryers
What voltage is required for the electric models??
  • 816 Answers
There should be a sticker somewhere that tells you the voltage for specific appliances. if it has the big weird looking plug,then its 220 volts. if it has a regular plug on it, its usually 110 volts. Good-day! check for the voltage marking on label.
Posted on May 08, 2014
What are the electrical requirements; 110V and/or 240V??
the voltage required is stamped on the plate on the electric motors
it will read
voltage
phase
current( watts)
duty cycle that plate tells you what the motor needs to run
Jun 23, 2016 | Jacuzzi Home
Will no Sears Dryer Model 110.61202013 run on a normal household current and plug?
the required voltage and cycles is on the compliance plate attached to the machine along with the model and electrical certification
If you utility supply is not as stated on that plate then it will suffer damage that will be unrepairable
Mar 07, 2016 | Dryers
I just tried plugging my new oven in (model number jrp24) and my GFI flips. The oven is off and the wires are connected properly. I live in a country that requires 220v, even though the oven says 120/
The model number according to GE says this is an electric oven.
It states that this oven will only be Hard wired and not supplied with electricity using a Plug. If it is gas, only one leg of the 220 volt power will be utilized. and the other usually colored white indicating natural, or green indicating Ground. Or, there will be a switch like on all computers that you will simply move to the selected voltage of the country that you live in and this will correct the high or low voltage. I hope this helps, without the full model # I will not be capable of knowing the actual voltage that the appliance works with.
Sep 14, 2014 | GE JRP24 Electric Double Oven
Electrical requirement
If you locate a manual for this unit it shows it at the end of the installation manual with all the specs.
Sep 05, 2012 | Eaton Powerware 9135 UPS (700465446) UPS...
Wattage of our Oreck Plus XL 2
Electrical Facts Germany | Voltage Converters Adapters | Europe ... There are basically two kinds of voltage converters. ... Adapting a television set, DVD player, or video recorder requires more than just a voltage converter. ... guide for the world traveler. World Electric Power Guide by Steve Kropola ...
www.german-way.com/electric.html - Cached
Dec 19, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Got a 62600 dryer and the power wont come on got power to the unit
Working with live electrical current can be very hazardous. Testing voltage output requires working with electrical current. Do not attempt this measurement without the proper tools and safeguards
To measure the voltage at an electrical outlet requires the use of a multimeter. Always test your test equipment for proper operation before use.
Set the multimeter to AC voltage. The markings may appear as VAC, AC V, or a V beneath a wavy line. Choose the AC voltage closest to the voltage you will measure. Standard current in home and businesses in the USA is in the range of 110 to 120 volts. Some circuits used for equipment such as dryers, air conditioners, electric stoves, ovens and other large equipment may use voltage in the range of 220 to 240 volts. These heavy-duty circuits can be identified by their non-standard outlet plugs.
While grasping the insulated portion of the probes (never touch the metal conductor during testing) place one probe into each of the two terminals. The multimeter will display the voltage.
Carefully remove the probes, being careful not to touch the metal part of the probes to anything or each other.
The voltage should typically test in the range of 108 to 121 volts for most circuits. If voltage is higher or lower, professional electrical service may be required.
Good luck;
Regards:
VOTIT
Dont forget to rate;
Jul 05, 2009 | Kenmore Dryers
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
New Dryer was purchased -- Tenant tells me he now requires higher voltage
Hello Paulcolletti,
I am not sure what you mean with your question.. Electric dryers typically use either 3 pole or 4 pole plugs that mate with the corresponding receptacle. If you already had an electric dryer there before, you need to make sure your power cord matches the receptacle. If it does not, most home goods stores ( like Home Depoit/ Lowes) and others carry the molded cord sets for that application and are reasonably easy to install. I fail to understand the low voltage versus high voltage comment as it pertains to a dryer. Please elaborate on this and maybe I can assist with a solution.. Good Luck...
Oct 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
