Question about Dell OptiPlex 3010 DT
Dell Desktop Fan Runs all the time and Amber Light
  • Dell Master
  • 998 Answers
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Posted on Mar 22, 2015
  • 3940 Answers
SOURCE: Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Posted on Jul 01, 2008
pagebor
  • 2785 Answers
SOURCE: Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Posted on Aug 08, 2008
ashish13
  • 75 Answers
SOURCE: My Dell 9100 desktop won't start.
Hey mate... Now there could be a number of things wrong with your PC.. First thing is that on the back of the main tower there are 4 Lights that glow if the system is ok but in case of issues they glow in different patterns according to the potential problem... look out for those lights n refer em to this chart
http://support.dell.com/support/edocs/systems/dim9100/en/SM/adtshoot.htm#wp1054146
Also in case of potential component failtures the system gives out beep codes in patterns (maybe the sounds u hear at startup)... Do a quick check
Now regardless we can perform a basic troubleshooting...now you seem to be tech savy enough so do one thing... remove all the chords from the system... then hold dowm the power button to discharge the flea power... now remove all the components one by one n reseat them immediately... this will reset the connections n then try n restart again... if the problem persists then post the 4 led code here n we'll go from there mate :-)
Posted on Feb 11, 2009
hacker8499
  • 74 Answers
SOURCE: DELL XPS 700 AMBER LIGHT
you don't tell us from where coming the amber light from the cpu or from the monitor?
Posted on May 29, 2009
  • 561 Answers
SOURCE: solid amber light ON Dell Inspiron 530 desktop.The
Hi
Please try the following
1) Remove ALL wires from thw back of the PC
2) Press and hold the power button on for approx 15 seconds
3) Replug only the mains power wire and the monitor cable and then retest
Please advise of outcome
I hope this has been useful
Posted on Mar 05, 2010
Why am I unable to boot my desktop dell
Several possible reasons, best (if not under warranty) to check RAM memory for faulty one, seems like possible memory of AC issues.
Aug 26, 2014 | Dell Dimension 9200 PC Desktop
Computer turns on won't boot fan runs fast
Are you getting any video display before the amber light goes off?
Aug 16, 2014 | HP Compaq Presario SR1830NX PC Desktop
Dell dimension c521
it could be and issue with the system board to confirm that try to run a HDD test once using an alternate video source to check id display coes on alt monitor...are u able to enter the BIOS check once.
Feb 12, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dell GX 260 optiplex desktop it was working fine all along - when i switched it on the other day, the power light stayed on amber, the monitor didn't come on, the desktop fan was on and it was at...
I have a Dell GX 260 optiplex desktop, when I connect the power to the computer, the computer turn on and off repeatedly, so the HD doesn't have the chance to spin up or the monitor to come on. Whyy, please help
Oct 12, 2010 | Computers & Internet
Amber light solid. Replaced the power supply ad the cmos battery. removed the memory and reconnected. Plugged back in and I hear the fan running kind of loud (louder than before) Still solid amber light
most times i have seen amber light, if it is where the pwr light is on front of tower means ur mother board might be fried. check capacitors one by one and make sure none are extended or leaking. dell has had this issue before when they sent out a bad batch of capacitors. may last it job was mostly issues with this. good luck.
Dec 11, 2009 | Dell OptiPlex GX520 PC Desktop
I have been getting beep codes with no monitor and the codes suggest reseating memory. I've done that and now my fan runs really fast and the power buton is amber with still no monitor
The amber light means hardware failure, you'll have to figure out which hardware failed.
If you would like to ship it to me to be repaired, contact me at info@taeckertindustries.com
Nov 06, 2009 | Dell Dimension 8400 PC Desktop
May 29, 2009 | Dell XPS 700 PC Desktop
Jul 01, 2008 | Dell Dimension C521 PC Desktop
Dell OptiPlex 3010 DT Logo
69 people viewed this question
Alun Cox
