Question about Microsoft Xbox 360 Console
My disc draw has come out
My disc draw GT stuck I pulled it and it came out
    Genius:
  • 1,056 Answers
You are going to have to replace the DVD drive, there is no way to repair the one you broke.
You can get the drawer to go back in, but it will never function like its suppose to again.
Posted on May 09, 2014
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 58 Answers
Do you mean the plastic facia for the dvd drive or the full drawer from the xbox?
If the drawer has come out then there's an issue because if you get a new dvd drive you have to flash it to the xbox (depending on model but specialist equipment may be needed) alternate way to replace dvd is to transfer the dvd motherboards over from the old dvd into your new one which does require soldering
This is a 2008 Lite-on i replaced with a 2009 Lite-on to get mine working again, cost me 25pound on ebay for the dvd drive. this way does not require the dvd to be flashed, just fit back into xbox and power up.
How do I open my disc draw it is stuck with a disc in it
I have had success by putting the computer on end with the disc
drawer facing upwards. then gently tapping the drawer as you hit the eject release
Nov 05, 2014 | Lenovo IdeaPad U260 Laptop Computer -...
Tip
Stuck DVD, Can't get CD/DVD out of draw?
This is a common problem, for whatever reason your disc is in the draw and you cant eject it, or get it out..Here is what to do to get the disc out.... get a straightened paper clip, thick needle, or very small diameter stiff wire.. now look on the front of the device you should find a small hole.. push the wire into this hole and push it right in and you will hear and feel a click and the draw will pop open, gently pull it right out, there is your disc.
on Jan 29, 2010 | Computers & Internet
Cd stuck in Dennon cd player so draw will not close nor can I use the player
Try undoing the screws around the side and back. Top should then slide off and you should be able to remove disc. Make sure it's NOT PLUGGED IN!!
Nov 29, 2013 | Denon Audio Players & Recorders
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
I amusing a Brother HL-2140. Recently, the paper curls up and gets stuck in the tray, and will not move forward. I have cleared the pat several times, but the paper is stuck in the rollers, and it tears...
Turn off the machine, > Open the front cover > remove the drum, cartridges, > and check if you can see the jammed paper or not, if so pull it out slowly. If you can't see the paper, close the front cover > Pull out the Tray completely > and once again check if you can see it or not, if so pull it out. Still it's not there? then install the tray and open the back door > pull the tab to open the fuser unit and pull out the paper, you can also pull out the fuser unit.
You can also refer to this tutorial from Brother Solution center..how to clear paper jam
Good luck.
Thanks for using FixYa.
Aug 13, 2010 | Brother HL 2140 Laser Printer
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
Xbox will not read disc. When I plug in the Xbox it powers on fine. I insert the disc and close the draw. monitor still show me the draw is open.
It sounds like your DVD drive's laser is malfunctioning. Either that or the tray is not closing all the way. You'll have to open up your console and see if the tray is stuck. If it's not stuck, it's the DVD drive's laser.
You have a few options:
1) Decrease the resistance on the laser to increase power, and it may be able to read the discs again. A guide for that can be found here.
2) If that doesn't work, or you do not wish to do that, you can replace the laser head all together. Replacements can be found on eBay. You can follow this guide to replace the laser head.
3) You can replace the DVD drive completely, but it will require taking the original drive's firmware and putting it on the replacement one. The guide for that can be found here.
Dec 10, 2009 | Microsoft Xbox 360 Console
I have a dimensionsC521 that has swallowed my cd disc. It is an awkward cd slide since the cd does not stand upright and so I usually tilt the tower over so it doesn't slip out. Now it slipped out and the...
I suspect this is more a mechanical problem than a power or software problem
I suggest powering down your PC,
Laying it down so the CD draw is flat,
Fashioning yourself a home made cd draw ejector device (otherwise known as a straightened paper clip),
Pressing the paper clip quite firmly into the tiny hole next to the CD Draw (it should unlock and open slightly)
Carefully and gently pulling the CD Draw out just enough to see inside and find out where the disc has got to
Physically maneouvering your whole PC to get the disc back onto the tray where it should be
Then you can either manually pull the CD Draw out and remove the disc or start the PC while it's laid down flat and see if the CD Drive auto closes and begins to spin now the disc is properly seated
If your PC doesn't have the tiny hole on the front of the Drive or if the CD Disc cannot be seen at all or cannot be persuaded back onto the tray then it's time to start opening up your PC case and removing the CD Drive for more attention
- NOTE if your PC is still under warranty Opening the Case may invalidate that warranty, check this before you proceed -
Treat Everything Gently and Good Luck!
Sep 16, 2009 | Dell Dimension C521 PC Desktop
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
I have a disk that I put in my old computer, just got a new computer and can't get it in---why?
hi adpelle
is the disc stuck in a cd /dvd drive draw ?
(if so there a small pin hole on the cd / dvd unit you can push a paper clip into it to open the draw .
it's on the left under the draw this will eject the disc in side )
if not disc in draw can you post back more details of this disc and what the problem is .
reagrds
riz.
Apr 16, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
