Question about Alcatel Lands Phones
Require manual for alc atel temporis 200 phone
    Sergeant:
  • 296 Answers
2005 equinox headlight control module location
Doesn't have a headlamp control module . Has a headlamp relay , located in the instrument panel fuse box.
Headlamps
The headlamps may be turned on 2 different ways. First, when the driver places the headlamp switch in the ON position, for manual operation. Second, with the headlamp switch placed in the OFF position activating automatic lamp control (ALC).
The LH HDLP and RH HDLP fuse in the fuse block - underhood, supply battery positive voltage to both low and high beam lamps at all times. For manual operation, when the headlamp switch is in the ON position, the headlamp switch supplies ground directly to the headlamps and to the body control module (BCM) on the headlamp low or high beam signal circuit, depending on the position of the headlamp dimmer switch. The BCM uses this signal to determine if the conditions are present to illuminate the daytime running lamps or park lamps.
For ALC operation, the BCM receives a signal from the ambient light sensor indicating a low or high ambient, outside, light level. Under low light conditions the BCM grounds the headlamp relay control circuit energizing the headlamp control relay. The now closed relay supplies ground through the headlamp switch to the headlamps and the BCM on the headlamp low or high beam signal circuit, depending on the position of the headlamp dimmer switch. When the BCM grounds the headlamp relay control circuit it also grounds the park lamp relay control circuit illuminating the park lamps. The headlamp relay is grounded at G203.
If the engine stalls with the headlamps in the ALC mode under low light conditions, the headlamps will be controlled OFF during cranking.
The conditions necessary for the BCM to activate the ALC mode are as follows:
• The ignition switch is in the RUN position.
• The headlamps are in the OFF position.
• The park brake is released. If the park brake is applied after the ignition key is placed in the RUN position the ALC is not effected.
Apr 11, 2018 | Cars & Trucks
I have a 2007 chevy suburban with dvd in head rest where is fuse located , looked in owners manual could not find.
10A SEO/ALC FUSE 54 in the underhood fuse block is the basic source of power but an additional 5A DVD FUSE (possibly inline) connects power to the IGN 1 terminal of the DVD control module. It's anybody's guess as to what GM thought SEO/ALC was supposed to mean.
Jun 29, 2017 | Chevrolet Suburban Cars & Trucks
How to disable the annoying tone during the mute on alcatel temporis 700??
no way to do this, Temporis 700 does not use standart MUTE function - it use HOLD function instead. And Hold function means that you must inform other side you put it on hold. (our customer has the same problem, the only suggestion: read usermanual or try it before buy)
Feb 01, 2012 | Alcatel Cell Phones
How to switch to Tone mode in Alcatel Temporis 03-RS corded phone
Please see the user's manual from
http://www.atlinks.com/sites/default/files/temporis03_user_guide_UK_SP.pdf
At the first page it shows a switch placed on the left side of the handset (handset with the buttons facing to you). Slide that switch.
Jul 01, 2011 | AT&T Lands Phones
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
Where is the a.i.r. pump located
The air pump for the secondary air system (emission control device) is located under the battery. If you do replace it, replace the check valve too, it is on top of the exhaust manifold and connected to the pump with a hose. The check valve fails and ruins the pump. Source(s): http://repairpal.com/volvo-850-1997/comm…
http://repairpal.com/air-pump-check-valv…
OR
I think they are talking about the pump to provide vacuum to the climate control when the turbo is putting boost in the intake manifold. The vacuum can come from an electric pump or from an engine driven pump, something like an old engine driven fuel pump. I needed an electric pump for my 765T, and all the wrecking yards wanted to sell me the engine driven form. (A new one was $500, and it wasn't that important to me.)
An engine that takes the engine driven pump will have a hole in it while the others will not have a hole. Source(s): 35 years maintaining my own cars, including 17 years with a 1985 765T
OR
Rear Suspension Leveling Air Compressor
RH front of vehicle, attached beneath the fascia
Rear Suspension Leveling Air Compressor Relay K19
Lower I/P, to the RH side of the steering column, on the relay box
Automatic Level Control System Operation Check
Support the rear wheels or support the rear lower control arms when certain tests require raising the vehicle on a hoist. Use two additional jack stands in order to support the rear lower control arms in the normal curb weight position when a frame type hoist is used. Refer to Trim Height Specifications in Suspension General Diagnosis.
Refer to ALC Suspension System Check for electrical troubleshooting of the Automatic Level Control (ALC) system, or if DTC's are present.
Diagnosing Leveling Complaints Without DTCs Present Procedure
Perform the following preliminary inspections before performing the system performance test:
Inspect the ignition (pin A & pin H) at the ALC sensor connector.
Ensure that the ignition (pin A & pin H) at the ALC sensor connector connection is secure.
Inspect the ground (pin E) at the ALC sensor connector.
Ensure that the ground (pin E) at the ALC sensor connector connection is secure.
Inspect the ALC sensor link.
Ensure that the ALC sensor link is properly secured to the actuator arm.
Inspect the ALC sensor actuator arm for damage.
ALC Diagnosis Table Step
Action
Value(s)
Yes
No
Has the ALC compressor assembly and the air tube been replaced?
Go to Step 7
Go to Step 2
Raise and support the vehicle. Lifting and Jacking the Vehicle in General Information.
Inspect the air tubes running from the ALC compressor to both rear shock absorbers.
Inspect the air tube connection at the ALC air dryer.
Are the air tubes damaged and/or disconnected?
Go to Step 13
Go to Step 3
Squeeze the left rear shock absorber in the middle of the air sleeve.
Did the air sleeve slightly compress?
Go to Step 5
Go to Step 4
Operate the ALC system for 60 seconds.
Test the air tube-to-air dryer connection for leaks using a soap bubble solution.
Is a leak evident?
Go to Step 20
Go to Step 5
5
Disconnect the air tube from the ALC dryer.
Connect the Pressure Gauge to the ALC dryer.
Close the toggle valve on the Pressure Gauge .
Operate the ALC compressor.
Did the pressure build to the specified value?
80 psi
Go to Step 6
Go to Step 10
6
Shut off the compressor when the pressure reaches 80 psi.
Monitor the gauge for 1 minute.
Did the pressure leak down?
Go to Step 10
Go to Step 7
7
Connect the Pressure Gauge to the right rear shock absorber. Ensure that the toggle valve on the Pressure Gauge is away from the shock absorber.
Close the toggle valve.
Pressurize the shock absorber at the toggle valve on the Pressure Gauge to 80 psi.
Did the system leak down?
Go to Step 11
Go to Step 8
8
Use the toggle valve on the Pressure Gauge in order to slowly release the air pressure.
Disconnect the Pressure Gauge from the right rear shock absorber.
Connect the Pressure Gauge to the left rear shock absorber.
Pressurize the Pressure Gauge to 80 psi.
Go to Step 12
Go to Step 9
9
Disconnect the Pressure Gauge from the left rear shock absorber.
Connect the Pressure Gauge , inline, at the tee near the rear of the vehicle.
Reconnect the air tube to the ALC dryer.
Open the toggle valve on thePressure Gauge .
Using shop air, pressurize the system to 80 psi at the service connection of the Pressure Gauge .
Monitor the pressure gauge for 1 minute.
Go to Step 14
Go to Step 20
10
Replace the following components:
• Replace the ALC compressor. Refer to Air Compressor Replacement .
• Replace the air tube. Refer to Air Tube Replacement .
Are the replacements complete?
Go to Step 20
11
Slowly open the toggle valve on the Pressure Gauge in order to relieve the air pressure.
Replace the right rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Reconnect all of the air tube connections.
Is the shock absorber replaced, and are all of the air tube connections reconnected?
Go to Step 20
12
Replace the left rear shock absorber. Refer to Shock Absorber Replacement in Rear Suspension.
Go to Step 20
13
Are any of the air tubes damaged?
Go to Step 14
Go to Step 18
14
Replace the air tube that runs from the air dryer to the two rear shock absorbers.
Is the replacement complete?
Go to Step 15
15
Remove the ALC air dryer from the compressor assembly.
Shake the ALC air dryer with the head connection down.
Did water/moisture come out of the ALC air dryer when the dryer was shaken?
Go to Step 16
Go to Step 17
16
Replace the ALC air dryer. Refer to Automatic Level Control Air Dryer Replacement .
Go to Step 17
17
Replace the air compressor head. Refer to Automatic Level Control Air Compressor Head Replacement .
Go to Step 18
18
Install the ALC compressor on the vehicle.
Is the ALC compressor reinstalled, and are all of the air tube connections reconnected?
Go to Step 20
19
Repair the air tube-to-air dryer connection leak.
Is the repair complete?
Go to Step 20
20
Reconnect all of the connectors that were disconnected.
Reconnect all of the components that were removed.
Clear all of the codes with the ignition ON and with the engine OFF.
Wait at least 5 minutes.
Is the rear of the vehicle trim level?
System OK
Aug 04, 2010 | 1998 Cadillac Catera
On board Realtek ALC 660 @ via VT8237A HighDefination Audio
Hiii, to download the driver for your ASUS motherboard, please visit this website i.e. http://support.asus.com/download/download.aspx?SLanguage=en-us Here, you just specify your requirement or scan your pc for driver as a new user. You can find your latest sound driver here. After downloading the driver you just install it one by one and after single installation please reboot your computer.
Feb 19, 2009 | Computers & Internet
Alc sensor is activated. need to de activate
alc sensor activated on cell phone. How to deactivate ?
Nov 09, 2008 | Lands Phones
I need to get a Manual for ClearVoice 200
I have spoken with the manufacturer and they are willing to replace the manual for an 8.00 dollar fee. You will need to contact the manufacturer with all the required information. You can do so by emailing them at info@telemergency300.com or you can can call them at 631-467-6700
If you need any further instruction please use the following link
http://www.telemergency300.com/
Jun 04, 2008 | Telemergency ClearVoice 200 Emergency...
Lands Phones Logo
Top Alcatel Lands Phones Experts
Gyula Lacz
Unlockingcom
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
