Question about Makita 9005B 5" Electric Angle Grinder
How to fix makita 5" grinder
I have a amkita 5" angle grinder and evrytime i pull the trigger there's a sparks coming from inside.
    Sergeant:
  • 458 Answers
It is time to replace the trigger switch.
Posted on Sep 04, 2014
SOURCE: something wrong with the armature
If the armature is shot, it will spark a lot where the brushes are touching the armature comutator. To remove the armature:1 Remove brushes. 2 Remove 4 screws holding the gear box. 3 Pull away gear box from the body. The armature may come with the gear box or not, it's only pushed in, so you should have no problem to disassemble it. If the armature stay in the grinder, use two skrew drivers to pray it out. You may not see anythink wrong with it, but it may be no good . That's Makita special, they don't make it good as they used to. The price for new grinder is about $130, for armature $65. field $40
Posted on Mar 08, 2009
  • 142 Answers
SOURCE: 7" makita grinder stated to smoke cleaned it all
sounds like it needs new brushes
Posted on Jun 13, 2010
  • 313 Answers
SOURCE: Makita Angle Grinder not working
check inside for any loose connections plus check the brushes. if like you say it is smoking it could be a trip to the wheelie bin for that one.
Posted on Jul 29, 2010
  • 119 Answers
SOURCE: How do you get to the inside of a makita 4.5"
there is a screw in the bottom of grinder next to the power cord, that's all you have to take.
(althought I don't know the model of your grinder, the most of makita brands have the screw right there) good luck!
Posted on Jul 02, 2011
  • 39 Answers
SOURCE: replacing the gear on makita angle grinder
Are you replacing both gears? The armature gear (pinion) is usually held on with a nut or else is pressed on. The spindle gear is also pressed on. Most spindle gears will come as an assembly with the gear and spindle and housing all together.
If yours doesn't, then the spindle will need to be pressed out of the housing, and then the gear pressed off of the spindle. (Always replace the grease as well when replacing gears.)
Posted on Apr 24, 2012
Makita ga9020-230 making grinding noise and then starting flicking sparks even after replacing the brushes, please help
It sounds like the armature is shot. When the armature goes bad you will see excess sparking from the brushes.
Jul 04, 2011 | Makita GA9020 Angle Grinder
Jul 02, 2011 | Makita Saws
How do I change th4e3 brusheson a Makita grinder?
If it is the one listed in the header 9005B first unplug the tool and then get a good screwdriver and you will find 2 brush caps that need to be removed and pull the brushes out, Be careful not to crack the brush caps and if you do think about replacing them. Let me know if you need more assistance.
Mar 30, 2011 | Makita 9005B 5" Electric Angle Grinder
Jul 29, 2010 | Makita Angle Grinder 4.5" 9524NBX
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
Armature problems
Unplug tool and then remove the brush caps and brushes, at the front of the tool are 4 screws that need to be removed after removing them you might have to pry the gearcase from the motor housing and then it should just pull out if there is no problems with the field having been hot and melted. Let me know if you need further assistance
Mar 06, 2009 | Makita 9005B 5" Electric Angle Grinder
Something wrong with the armature
Can't get grinder to turn on. Checked brushes, cord, trigger/switch. Any suggestions?
Did you check continuity to the field/brush holders. They have a garter spring that sometimes became overheated and broke. It seems like you have done everything else. Let me know
Feb 25, 2009 | Makita 9005B 5" Electric Angle Grinder
Makita 9005B 5" Electric Angle Grinder Logo
181 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
