Question about Wolff Sunquest Pro 16SE Limited Edition Gold
Why would every balb be out
The tanning bed turns on but not the bulbs
  • 47 Answers
Might be a starter.Just like a fluorescent tube.
Posted on May 08, 2014
How to replace bulbs in tanning bed
Without the specifics of your bed, I can give you some general info.
  • The first thing you need to do is remove the acrylic. Depending what type of bed you have, this may require a screw driver to remove the metal retaining strip on the outside edge of the acrylic.
  • Set the acrylic aside, & remove the burnt out bulb(s).
  • Depending on the type of bulbs you are using, you may need to place adapters on each end (these can be removed & reused from your old burnt out bulbs).
  • Regardless of bed type, most have one thing in common when it comes to bulb terminals. One end of the bed will have a stationary terminal, & one end will have a springy one.
  • Place one bulb end in the spring side first, press in, & guide the other end into the stationary side.
  • Turn bed on for a test to make sure everything is working properly.
  • Replace acrylic (and retaining strip if necessary), and you're ready to tan :)
Jan 06, 2015 | Health & Beauty
Sunvision facial tanning bulb buzzing and flicker's and won't light
It is not the socket. If the bulb is installed correctly, there is a starter on the ballast that needs to be replaced.
May 07, 2014 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed
Check the bulb you adjusted, you probably got it in wrong, and shorted stuff out. Reset the bulb, and replace the fuses. At least you had fuses.
Nov 30, 2013 | Remington S 1007 Tourmaline Straightener...
Bed works fine, but no tanning results
Sounds like it has the wrong lights in it. Check to see if they are marked tanning lights
Dec 25, 2017 | Wolff Sunquest 16se Tanning Bed
2 tanning bulbsdont work. could it be the fuse in the bed
maybe they burnt out. you can use an UV reader, which lets you know when to replace the bulbs. it tells you how much UV light is being outputted. When you replace your tanning lamps, it is ideal to replace them all at once.
look here for more info http://www.mastertanning.com/tips/23/tanning-lamps/
Feb 26, 2013 | Health & Beauty
Do I need to worry about how often salons change the bulbs in their tanning beds?
Yes - even though in theory tanning bulbs can last up to 1,000 hours, if they are not changed very regularly, they can seriously affect the quality of your tan. Bulbs should be replaced after 500 - 600 hours use.
Feb 18, 2013 | Health & Beauty
Wolff Sunquest Pro 16SE Limited Edition Gold Logo
75 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
