Question about Britannia Kitchen Ranges
Britannia Nebraska American style fridge freezer the freezer is getting very cold and icing up the temperature on the front panel is 5What is the normal periodThanksPhil
  • 833 Answers
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Posted on Mar 09, 2008
SOURCE: Flickering display panel on Whirlpool
Also have the same problem of flickering Whirlpool American Fridge Freezer display, which seemed to start when I changed the filter.
Posted on Sep 08, 2008
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
Posted on Dec 10, 2008
SOURCE: Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Posted on Sep 20, 2009
shastalaker7
  • 1515 Answers
SOURCE: cool ncool model. fridge no longer drops temp
Hi, I am a Refrigeration Contractor, and have seen this problem many times. You say that fan motor is working at the lower back which is the condenser fan motor and the fan inside freezer which is the evaporator motor. With the ice build up and no cooling, you have a faulty defrost timer. This keeps the ice from building up and a balance through out the unit, an even temp. You may be able to replace this yourself, if you are inclined to give it a try.It is a electrical timer clock, normally located at the back of the unit on the bottom corner, not positive the side, but it has 2 screws that hold it in place. When looking at it, it will have what appears to be a nylon adjustable screw head that is made to where you should (not) be able to adjust it with a regular driver. Now, sometimes they are located elsewhere and you will have to hunt for it. If you have a schematic pasted to the back, it will lead you to it and will be marked DFT. Depending on this timer, it may or may not have a capillary copper line attached to it leading to the freezer.These are more difficult to replace. Most are small and easy to remove. It is the defrost timer, and will have you up and back online. Best of Luck, and Sincerely,
Shastalaker7
Posted on Nov 21, 2009
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
I have a Britannia nabraska side by side fridge freezer. All of a sudden the freezer compartment is not cold enough as though the door had been left open - but 24 hours later has not got colder
You may have a bad thermostat or you could just be frosted over inside. You'll need to look behind the back panel in the freezer for syntoms if unplugging to defrost doesn't work.
Mar 23, 2015 | Refrigerators
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Dec 09, 2013 | Electrolux Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Kitchen Ranges Logo
67 people viewed this question
Top Britannia Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Britannia Kitchen Range Expert? Answer questions, earn points and help others
