Question about Panasonic PT L735U Multimedia Projector
How do I invert the image on Panasonic pt-l735u projector?
It was ceiling mounted upside down but now sitting on desk right side up
4 Suggested Answers
SOURCE: Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Posted on Jan 15, 2008
stecon3248
  • 57 Answers
SOURCE: I have a RS232 Serial controlled Panasonic
The above link will allow you to download the manual with the all of the serial commands and how to use them.
Good Luck
Posted on Aug 15, 2010
ib_yang
  • 1098 Answers
SOURCE: image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Posted on Oct 15, 2010
Display upside down
you can set the image by setting in the Menu
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 24, 2014 | Panasonic ET-LA735 Projector Lamp for...
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Image on screen is upside down
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Image is upside down
Hit the menu/select button to bring up the menu either on the projector or on the projector remote then go down until advanced is highlighted then press the menu/select button then move down until Ceiling Project is highlighted and hit the menu/select button again to get the image right side up. If you have the manual for the projector this information can be found on page 34.
Dec 09, 2008 | InFocus LP 530 Multimedia Projector
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
Its projecting upside down!
check the projector menu. there will be a setting for image orientation. it can be set for normal or inverted. inverted is used when the projector is hung from the ceiling.
Oct 20, 2006 | Panasonic PT L711U Multimedia Projector
Panasonic PT L735U Multimedia Projector Logo
41 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
