Question about Dyson DC25 All Floors Bagless Upright Vacuum
My wife has one of those nice Persian Rugs. Our daughter spilled grape juice on it. Is there any rug cleaning tactic we can implement to save the carpet? Bryanflake1984|
    Master:
  • 752 Answers
Search on the internet under "how to clean grape juice from a wool carpet" (assuming the carpet is wool not silk), you'll find lots of methods. For example,
http://www.wikihow.com/Remove-Fruit-Juice-Stains-from-Carpet
http://www.ehow.com/how_2377493_remove-grape-juice-stains-carpet.html
http://www.howtocleanstuff.net/how-to-clean-juice-stains-from-carpet/
I am not recommending these or any other methods.
8.May.2014
Posted on May 08, 2014
SOURCE:
Why am I unable to push vacuum forward on new area rug. But will work pulling backward. Works fine on old rugs and floor
It might be that the new rug has a backing that is not as stiff a the other rugs which can cause a rug to bunch up making it hard to push the vacuum forward.
Feb 23, 2015 | Dyson DC25 Animal Upright Ball Bagless...
Cannot push vacuum forward on new area rug. But will work pulling backward. Still works on old area rugs and floors.
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty using your DC25 on this particular new area rug. As you've confirmed the vacuum works as normal on other rugs and hard floors, it doesn't sound like there's a fault with the vacuum itself.
As lightweight area rugs are not fixed to the floor, it's possible for the rug to lift and seal against the soleplate of the cleaner head, due to your DC25's powerful suction. As this will reduce the amount of airflow entering the cleaner head, you may need to use more push force than usual when vacuuming this type of flooring.
We would encourage you to check directly with the rug manufacturer, as they'll be best placed to provide information on correctly caring for this particular floor type.
If you'd like to discuss the issue you're experiencing with our experts, you're welcome to call us directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Cleaning oriental rugs leaves lines on some rugs
Hey Jeff! Some Oriental rugs should not be cleaned with water. You may want to contact the manufacturer of the Oriental rugs regarding their care instructions.
Mar 04, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Feb 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover all terrain dual v spin and scrub 12 amps
All of the hoover cleaners use air to spin the brushes the air intake is probably clogged. There is a Little clear window on the top of the machine pull that off and underneath is a little screen clean that out and that should fix your problem. If you need any parts or cleaner for your machine visit www.stevessewandvac.com
Aug 12, 2008 | Vacuums
Dyson DC25 All Floors Bagless Upright Vacuum Logo
155 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
