Question about Craftsman Professional 24 hp 42" Yard Tractor ()
How do I remove blade spindle from housing on Mountfield 1436m? I have removed the pulley and the blade boss. I have removed the circlip from the blade side of the spindle. The spindle still seems ver
I have removed the pulley and the blade boss. I have removed the circlip from the blade side of the spindle. The spindle still seems very firmly stuck in the housing. I am assuming I need to hammer the spindle either upward or downwards but have had no luck in either direction so far.
  • 656 Answers
This will require a heavy three pound hammer and two pieces of hardwood to support the hub. It is really supposed to be pressed in. But support with blocks, use a piece of oak between shaft and hammer to keep from damaging the shaft. I t may require many hard blows. If you have a press, that is the way to go. Spray some PB blaster penetrant on it and let it sit for awhile. You should have to pound down away from the snap ring. Hope this helps, please post a comment that this is solved on fixya.com. So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on May 09, 2014
  • 376 Answers
SOURCE: I had to get a new mandrel housing which goes
You have to remove the nut on top of the pulley. With the pulley off, the shaft will slide out the bottom with the blade. Don't forget when you put the pulley back on, the washer/spacer goes BETWEEN the pully and housing, NOT on top of the pulley. Dwain
Posted on Jun 08, 2009
bbreton
  • 437 Answers
SOURCE: need to remove pulley from spindle to replace
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
SOURCE: Blades will not disengage on lawn tractor
Your cable clutch is not engaging properly. Try to lubricate it with some grease. This will get the cable to slide. If that does not help, it will need to be replace.
Posted on Oct 03, 2009
  • 78 Answers
SOURCE: I changed the blade mandrel from my 42 inch cut
Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
GOOD LUCK
MIKE
Posted on Oct 22, 2009
  • 95 Answers
SOURCE: Have 54 inch Craftsman mower deck that I am
Depends on how old the deck is. Some of the older spindles and mandrels were not made to came apart. The newer ones you can put the nut on the top threade to protect the threads and a couple of taps it should come out. If you have a model number you can got to sears web site aa they will have an exploded view. http://www.searspartsdirect.com/partsdirect/index.action
Posted on Mar 21, 2010
How do I put a spring back into a mountfield sp544
sp544??? is it a 534 or 454 possibly? either way i think they have mountfield rv engine,you will need to remove the recoil housing assembly,remove the rope pulley (think the centre pulley screw is left hand thread) then if the recoil spring is undamaged you can wind the recoil spring back into the recoil housing
Mar 10, 2015 | Garden
How do I fix a loose blade.
By loose blade I assume you mean that it can be moved up and down at the tip of the blade. It is most unlikely that the central nut has come loose, but check anyway. If this nut is tight and the shaft is loose in the bearing this means the bearing has worn out. Remove the deck from the machine. Photograph the run of the belt as this has to be removed. Also the direction of the grease nipple. Remove pulley from loose spindle. Turn deck on its edge or mount on two saw horses or similar so you can get to top and bottom of spindle bolts. Remove cutting blade. Remove spindle housing and clean area so no rubbish gets caught when reassembling. Otherwise spindle may be set different and mower will leave a line of differing cut. Take spindle to vise and remove any retaining nuts or circlips from shaft and clean as clean as new. Apply light oil or CRC etc to help move bearing along shaft. Open vise wider that outside of bearing, usually 44 to 50mm [1 3/4" to 2"] and refit nut on thread. Check nut is always spaced free of top bearing. With cushion of hardwood or nylon tap the shaft to move it down with lower bearing coming out of spindle housing. To remove top bearing from housing, turn housing up other way and use a wooden shaft such as a broom handle to tap bearing free of housing. Clean out grease and replace when reassembling. Do not reuse other bearing. They are cheap and likely to fail shortly anyway. These bearings usually have no seals on inside.
Sep 27, 2014 | Garden
Replacing bearinon spindle housing
Remove deck and place on two boxes or saw horses so that you can access both top and bottom of bolts holding spindle housing. Remove drive pulley from spindle. Remove cutting blade. Remove four bolts holding spindle housing to deck frame, noting which way grease nipple is pointing. Take spindle housing off and scrub deck frame clean of rust etc and also clean housing with wire brush. To remove bearings, look for retainers such as nuts or circlips. Remove these and ensure that the shaft is clean so bearing can be slid off. Apply CRC or light oil to assist bearing removal. Use a vise and set jaws wide enough that the bearing outside can fit between. This is usually 45 to 50mm. [1 3/4" to 2"] Place a hard wood block [or something that will not bruise the thread such as solid nylon] and screw nut well on to thread but make sure there is space for movement between nut and bearing. Firmly tap spindle end. Shaft should go down into top bearing and bottom bearing should start to emerge between vice jaws. Make sure that there is always space between nut and bearing before knocking end of shaft again. To knock top bearing out, place it on bottom over vise jaws and take a length of wood such as a section of broom handle and knock it out. Normally there should be no seals on the inside of these spindle bearings as they are greased from a grease gun thru the grease nipple.
Sep 26, 2014 | Garden
How do I replace the bearings on the mower deck spindle housing on my toro mx 5060
To replace spindle bearings: Remove deck and either rest on two saw horses or similar mounts, or stand on its side and fix to make safe and secure. Photograph the belt layout and also the grease nipple so you can easily refit.The object is to access the top and bottom of the spindle. Remove cutting blade. Remove pulley on top side. I reccomend that you also remove the spindle housing from the deck. You can remove bearings while still fitted but it is not so easy. Clean the shaft and remove any circlips or retaining nuts from spindle. Take the unit and clean shaft as clean as new. Use emery paper if necessary. Use light oil or CRC to lube the shaft to slide bearings off. Do not hold shaft in vise as this will cause deformation of the shaft surface and jam the bearing. Place lower side of housing on vise which should be open slightly more than bearing outer diameter. Take hardwood or industrial nylon [to protect the thread from bruising,] after refitting nut on shaft thread, and ensuring there is space between nut and bearing, tap down firmly with hammer. The shaft will move more easily after the initial freeing up. When it moves easily remove nut and tap down with wood between hammer and thread end. To remove the top bearing use a wooden shaft, a broom handle is ideal. The replacement bearings should have no seals on the inside. Remove if necessary. Make sure to scrub clean both housing end and deck where the housing fits. Any rubbish there will cause lines in the mowing as it can tilt the blades. The thickness of paper can mean 3mm at the end of the blades!
How do I change the spindle bearings on a toro cutter zs5000
pull the pulley off and in the housing there should be a circlip that you remove then the spindle and bearings come out. check which way it comes out as it may come up and out in which case you will have to take off the cutter disc/blade mount.
Aug 16, 2014 | Cars & Trucks
WHY WILL MY BLADE NOT WORK ON MY HUSQVARNA RIDE MOWER AFTER HITTING METAL BAR
Sounds like the large nut on top of the spindle may have loosened up or the splines on the pulley are chewed up. Turn the blade and try to hold the pulley on top. If the blade turns and the pulley doesnt, its one of the two things I just described.
Jun 29, 2014 | Husqvarna Garden
How do I remove the blade spindle from the spindle housing on the cutter deck of Mountfield 1436m lawn tractor?
I believe you have to remove the spindle housing then remove the snap ring, ( you may need to clean and scrape to locate the snap ring) from the inside of housing. Now you should be able to press the shaft from the housing. Or if necessary support housing with blocks so as to drive the shaft from the housing. I would spin the nut on the shaft, then place a piece of hardwood on the shaft and drive it out with a three pound sledge. There may be a snap ring for the shaft and one for the bearings. There may not be one for the shaft as it bolts to the pulley. At any rate this should accomplish you goal. There is usually a snap ring that retains the bearings, if this is what you need to replace.
May 08, 2014 | Garden
Loss of power when blades engaded.
Remove deck belt from blade pulleys and Tri to spin blades by hand. If they don't spin freely, you probably need new spindle bearings but if you do need a new spindle I would replace the whole spindle housing... Just make sure the one (s) you buy has housing, spindle, bearings, nut and washer.
Jul 04, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to change the spindles on model 917.273220 craftsman tractor
The job is much easier and safer with compressed air and an impact. I would try really hard to find someone with air to borrow but if no air is available then wedge a piece of 4x4 between the blade and deck to keep the blade from spinning. BEWARE, the board can pop out and the spinning blade can be dangerous. Remove the deck from the unit. Remove the pulley first, hold the blade with your hand ( only if you have air/ impact) to prevent the spindle from spinning. Note the washer under the pulley. Then remove the blade, then the spindle bolts. Most AYP replacement spindles now come pretapped but if not place spindle in a vice and use one of the old spindle bolts ( they are self tapping) to make threads in the mounting holes. Then mount the new spindle in reverse order being sure to instal the washer between the spindle housing and the pulley. Again hold the blade with one hand and securely tighten the pulley nut with an impact. Also the unit probably has a blade brake arm and the spring holder is mounted by one of the spindle mounting bolts. Pay attention to its positioning before removal. If you have a heavy duty replacement spindle the notch on the bracket may not fit the new spindle. with a file or grinding wheel enlarge the notch on the bracket to fit.
Nov 25, 2012 | Craftsman Garden
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
Craftsman Professional 24 hp 42" Yard Tractor () Logo
69 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
