Star gold Error 1 displayed on monitor - Computers & Internet
  • 2,509 Answers
Difficult without knowing what the monitor is. Borrow a different monitor and make sure the computer is sending the correct resolution for your original monitor. That will also check the connector is OK.
If that does not lead you to a solution post more details about the monitor, make model etc.
Posted on May 08, 2014
TD2340 touch only works occasionally
If it has been working okay till now I would cleand up my hard disk after having unstalled the driver, do a disk cleanup and a defrag. MAYBE A RECOVERY TO A TIME IT WAS WOEKING.
aLSO TRY UNINSTALLING DIVER FROM WINDOWS, CHECK WHETHER IT IS IN STALLED IN PROGRAM MANAGER; IF IT IS REMOVE M THEN RESTART AND REINSTALL
Jun 06, 2015 | ViewSonic TD2340 23" LED LCD Touchscreen...
How to repair power supply
It's probably the 'invertor', not the backlight or powersupply. That is assuming that the power-led does turn on ?
Jun 29, 2014 | Dell Entry E2311h 23 Led Lcd Monitor -...
Dell 2214
Make sure you are confirming the changes. If the problem persists I would call the customer support desk for the monitor as you may be due a replacement.
Apr 18, 2014 | Dell P2214H 21.5" LED LCD Monitor - 16:9 -...
Error code 1 on vstar tourer 950
Hi, Jackie for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha 2010 Star 950 Tourer User Manual 1 Clock 1 Error Code Display 1...
Yamaha Fault Codes
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
OEM parts for Yamaha
Yamaha STAR XVS950 Owner Manual
Jul 11, 2012 | 2009 Yamaha V Star 950
Displaying "out of range" when plugged in
Hello white tiger, hi, the out of range error is usually caused by a very high resolution setup on your computer display card that windows installed (generic driver), the monitor simply cannot produce the resolution, set your resolution to a safe level like 1024 by 768, most monitors can display this resolution. The root of this error message is incorrect display driver, you need CD to install the display driver. Once installed your resolution will now be controlled to a safe settings were the monitor can display properly.
Aug 20, 2010 | Star Logic Monitor
Monitor turns on. display comes on then turns off immedialely. power of monitor stays on
nyfish60, Good news for you! You said "display comes on"!! I just hope you meant "I can see the WIN-desktop being displayed on screen". The bad news is that what you see has vanished in less than a finger snap! It seems that the "cold-cathode-fluorescent-lamps" hung across the rear (reverse side) of the glass LCD panel are not sustaining output of WHITE LIGHT . This could be due to a failure of some component(s) on a printed circuit board inside the monitor. The board is called the "switch-mode-power-supply"/"CCFL inverter". (inverter=electronic ballast) When the SMPS detects a fault condition with itself or the inverter it will go into full or partial shutdown mode. Partial=you see with aid of a bright flashlight 1 inch from screen a very faint displayed image on the lcd panel. Full= you see nothing!!! If pc that your Star Logic was connected to functions ok with subed-in known good monitor, then you or qualified electronics technician will need to do the repair. Read my fixya profile for more options. Report back here and do additional comment if you find out DIY is what you will try. The condition of your unit is same for many thousands more. Hope this helped.
12fixlouie
Feb 25, 2010 | Star Logic 17" LCD Monitor
Jvc- gr-d740 camcorder's cassette is not ejecting message is showing that unit in safeguard mode please advise
There should be an error code star with E-01 to E-06.Below is an example you have to make sure that which error code showing on your camera
Whenever some abnormal signal is input to the syscon CPU,
an error number (E01, as an example) is displayed on the
LCD monitor or (in the electronic view finder).
In every error status, such the message as shown below
E01 LOADING--------
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Sep 25, 2009 | JVC Video Cameras
No signal to monitor. Cable is fine and so is the Video Card -
your motherboard may be going out is your keyboard also acting crazy
Aug 15, 2009 | Impression Products Impression 7LSP 17"...
EHT PROBLAM
EHT Problemsymptems :1.If U find R457 - 33k,R452 -1k,R458 - 10k Resisters are Burnt In Zenith 14"and15" monitors To replaced all thease resisters and LOT FSN14B016S
2.HCL HCM 482M, 580M,582M, 780M models getting FAT - FAT sound coms from LOT when u switch on the monitor It's LOT Problem . replaced it
3.Samtron Samsung Models like 45Bn, 55V,56V when u switched on the monitor Power indicator (Led )glow one time First u can check Boosting FET IRF630 bitween (SMPS O/P to LOT supply) and also replace LOT.
4.some Old Gold star anlog and LG monitors If U found 12k Resister near by LOT and also bulched 1Mfd/63V capacitor
It's LOT Problem
Oct 04, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
