Question about Estate Washing Machines
Hot water stream when tub fills & how full tub gets super wash
I just had a new Estate Washer delivered. The hot water flow into the tub seems like a trickle compared to the cold water when it is filling. The screen in the hot water line is clear.
Also after I fill the tub with clothes and turn the water on it seems like the tub does not get enough water in it on super wash to handle the clothing I put in the washer.
The sales person said fill the washer with dry clothes and then turn the water on.
    Problem Solver:
  • 6 Answers
There should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Posted on Jun 22, 2009
Why would the hot water cycle of my washing machine not work?
The solenoid that opens to admit hot water is either defective or not being energized by control panel.
Jun 20, 2017 | Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Hot water keeps filling tub and does not quit
the washing machine is designed with a timer limit switch have the switch checked.
Oct 19, 2012 | Samsung WF448AAW 4.5 cu. ft. Front Load...
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
I can't get the cold water to fill the tub/rinse. the hot works.
Your problem is either a clogged COLD fill valve or a bad water fill valve. Turn the water off. Remove the COLD hose from the WASHER. Check the filter screen inside the valve for sediment. If you find sediment,remove the screen and clean it. Replace the screen and turn the water back on. If you do not find sediment on the screen,replace the water valve.
Sep 21, 2009 | Frigidaire FWS1339A Top Load Washer
Maytag Washer (approx. 7 years old) has slow stream when filling
Follow the two inlet hoses from the back of your machine. They should each end at a valve (one for hot and one for cold). Make sure that these valves are all the way counter-clockwise and that the hoses are not kinked or pinched.
Jan 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Washing Machines Logo
123 people viewed this question
Top Estate Washing Machines Experts
Marvin
Marvin
Justin Duby
Justin Duby
Jim Goldsmith
Jim Goldsmith
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
