Question about Home
How to remove a wooden fence - Home
    New Friend:
    Problem Solver:
  • 17 Answers
Duh?...axe, chainsaw or a towchain and a strong bumber...?!
Posted on May 08, 2014
What is perfect gate closer for garden gate?
Latching gates most popular gate in garden. Gate closer Chain connect to gate pipe with a eye hook. we provide best solution for latching gates in garden.
Jul 04, 2013 | Garden
How much should a wooden fence cost?
Of course it depends on the dimentions of your yard. Wooden fences can be quite expensive. look at this site, it includes installation costs:
http://www.homewyse.com/costs/cost_of_wood_fencing.html
Jan 31, 2013 | Home Fencing
What is the best fence I can use for my dog?
First, try to get a fence made from a durable material like aluminum or a wire fence. Of course you will compromise the looks...
don't get a wooden fence unless it is more expensive since big dogs tend to ruin them
A womp womp womp noise in the rear, tires are good, brakes look good, wheels are not warped, just had them balanced?
Go to a place that has a good smooth parking lot and a wooden private fence. Open all your windows and drive the car slowly as close as possible along the fence in order to pin point where the sound is coming from. The sound will echo back from the fence and will make it easier to pin point the area where the womp womp sound is coming from. Next thing you can do is lift the car up and place it on four jack stands in case you have a front wheel drive. If you have a front wheel drive and your car is on four jack stands, place you gear in nuetral and spin each rear tire separately to see which one is making the noise. Keep in mind that it might be a wheel bearing or if it a rear wheel drive and on four jack stands have someone drive it slowly while you listen for the noise. Some rear wheel drive differentials can make this noise if it is low on differial oil. Be very careful that the jack stands are on solid and making good contact with the car frame and flat on the pavement. Don't place yourself where the car can fall and hit you or run in to you. Good luck.
Dec 03, 2012 | 2002 Porsche Boxster
I installed the heater to the minimum distance from the ceiling due to the vent cap on the outside wall. The way I read the instructions it appeared the the end of the vent cap could not be within...
the flue is what is called a balanced flue, air in the other flue to burn inner flue is outlet gases , so you cannot just put any flue on there if is not in the makers instructions i would say no or contact the makes to be sure, how far is it from the fence
Dec 03, 2010 | Williams 1403622 Gas Compact Heater
Almost every shot that has straight lines is broken up ie roof eaves, parking lot lines, tops of fences/block walls, wooden decks is it my camera, me, or camera setting? camera is the kodak z1015 is ...
Do the pictures that were previously taken look good(before the problem appeared)? If yes then it is most likely to be an image sensor problem. IF all the pictures look alike then it is an LCD screen related problem instead.
Nov 02, 2010 | Kodak EasyShare Z1015 IS Digital Camera
I need a replacement handle
I had to replace all the wood on my grill. I used a wooden clothes dowel rod for the lid handle (planed one side flat, routed a grove for the insert and kept the old wooden insert), replaced the shelves with 5 in. redwood fencing slats (2 per side works better than the original 3 in. slats), and used a smaller dowel for the bin handle. It is now better than new.
Jun 28, 2010 | Patio Classic 2000 Series Grill
How can you adjust the hang of a ford escort door?
with a piece of 3x3 wooden fence post(i am serious)
if the door has dropped then put the post under the back/bottom part of the door and lift .....bodyshop mechanics will never let customers see this....
Apr 07, 2010 | 2000 Ford Escort
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Home Logo
23 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
