Question about Crosman (4032)
How do you program a key fob for a 1999 GMC Suburban 2500?
  • 1,087 Answers
Sounds illegal to me
Posted on May 08, 2014
I have a 1996 gmc suburban that i cannot unlock the driver's door. it was locked with key fob. i cannot unlock the door or open the door. the key will not unlock the door. help anyone?
if the key does not turn the lock spray it out with wd 40 run key in and out of lock few times.because everyone uses remotes to open their cars the waffers in the door locks get coroded and wont fall in proper place when key is inserted.give it good cleaning and see if it will unlock
Feb 03, 2013 | 1996 GMC Suburban
1999 GMC Suburban 2500: There is a grinding sound and a seize in the front tires when I make a sharp turn left or right at slow speed...Exp. pulling into a parking spot. What could it be?
Sounds like the truck is in 4 wheel drive, try turning the front driveshaft, it should turn freely if it is in 2wd otherwise you may have transfercase problem or your front diff is locked in
Oct 25, 2010 | 1999 GMC Suburban
How do I program the remote in a 19990GMC Suburban 1500
Garage door openers hold the key to this issue. Get a ladder and read the label on your opener motor. Now days they use rolling code technology and an invitation process.
Read carefully, there are two processes, one excludes ALL other remotes, and one adds new ones...
Essentially the process is press and hold button on transmitter, then press and hold programming button on the opener... When lights flash, the two have communicated and will assign themselves a new communication code (rolling code) on every use...
Doc
Sep 21, 2009 | 1999 Chevrolet Suburban
1999 GMC suburban locks seize in locked postion
I just bought a 1999 Suburban and all of the door lock actuators were bad including the rear (barn style door) while I was replacing the rear door acuator I noticed that even with the factory mounting bracket on the actuator it was causing the door lock rod (the rod from the keyed cylinder lock to the actuator) was on a bind......the solution I came up with is adding an additional 3/4" spacer between the factory mount bracket and the door attach point. this solved any binding and the door lock works great now........also I used a lubricant on all the doors where the rods run through the plastic guides, which seemed to help quite a bit! Hope this help's.
Aug 28, 2009 | 1999 GMC Suburban
Fuel line problem 2500 gmc suburban 1999
You likely are over filling the tank and the evap system cannot vent
Jul 25, 2008 | 1999 GMC Suburban
Crosman (4032) Logo
Top Crosman Optics Experts
Martin Clarke
Martin Clarke
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
