Question about Eureka 2961AVZ Bagless Upright Vacuum
Buning smell whenever I use my vacuum
My husband looked at it, changed the filters, but it has a buning smell whenever I use my vacuum. I'm afraid it'll start on fire.
  • judy May 28, 2012
    It can catch fire, Mine did. Thankfully, the fire shot upward. I was not hurt. I will never trust a vacuum that smells hot. Filters Cleaned, belt new, Cord in good condition. Turned Vacuum on, it made a funny noise. Smelled hot. That is when the flames shot out. Called the number located on the vacumm cleaner, they wanted me to drive 40 miles to a service Center. Not worth it.
  • 909 Answers
If it's a rubbery burning smell, check the belt for the beater, it could be rubbing on the sides or even broken.
Posted on Jun 22, 2009
MY DYSON DC24 SEEMS TO BE OVERHEATING
I'm sorry to hear you're having difficulty with your DC24. If the machine smells of burning, I'd advise you not to turn it on again, and to get in touch with us directly so we can provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Jan 16, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
I had used Dyson DC08 to **** out a wet car carpet. A few days later when using the V/C, there was a burning smell. Subsequently I washed the flexible hose, changed the pre-filter and post filter , but I...
We'd strongly recommend against using your Dyson to pick up water. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
Kind regards,
Jack
Sep 01, 2011 | Dyson DC08 Cylinder Bagless Canister...
A smell like burning rubber comes out of the vents whenever it is used. It starts as soon as the vacuum is turned on. I've emptied the filter, but maybe I need a new one? I don't think the suction...
Hi sevillekathe...
The problem is that you have is that hair,strings,etc has gotten wrapped around the beater bar of the vacuum and it is trying to slow down the motor but the motor will not slow down so the smell you smell is the belt burning up because it is slippling and creating smoke and smell
You will need to remove the beater bar from the bottom of the machine and clean the hair,strings,etc from around the bearings on each end of the beater bar.
Also check your filter bag, check the hose going to the vacuum if you have one for blockages, and once you have the beater bar off check your belt condition and look for blockages going to the bag.
Please take time to rate me
Aug 30, 2011 | Dirt Devil M083405 Versa Power Stick Vac...
Whenever i turn on my rainbow, it smells like dirty feet. i have cleaned the canitster, but it still smells and its coming from what looks like the plastic filter maybe?
there is a hepa filter on the back of unit, if you remove and than run the machine you can find out if that is where it is coming from. Most likely is.
Oct 17, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Nilfisk Family Vacuum - Strong Awful Odor
Not sure what a bacteria smell is perhaps you mean a mildew type smell.
If you have picked up something wet, start at the front of the vac and work your way to the exhaust.Change the front most filter first. Baking soda may help to eliminate some of the odor.
Personally as an allergy suffer, which you may be given the Brand I would remove all and let them and the tank air outside. Meanwhile install a fresh set.
Sep 13, 2009 | Nilfisk Family Vac Bagged Canister Vacuum
Not suctioning/
i would change the belt and filter.( belts need to be changed on average every 6 months). now if you smell a burn like an electrical smell the motor is gone.
Jul 19, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Smoke coming from lower base of vacuum cleaner
Make sure everything is dried off, I encountered the same symptoms once when I had some water remaining in the rotating brush after wiping the machine down.
May 19, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell
Replace the belt. It is probably stretched and is slipping. This will produce the smell your describing. These belts should be changed at least once a year.
Aug 24, 2007 | Hoover U5753-900 WindTunnel Bagless...
Eureka 2961AVZ Bagless Upright Vacuum Logo
288 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
