Sharp AR-M620N Copier Logo
A
Anonymous Posted on May 08, 2014
How do I clear my sharp ar m260n machine?
I need to clear the screen so I can use your fix to clear the Code: H-01. Thank you!
Gift Ntwana
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 66 Answers
  • Posted on Apr 21, 2016
Gift Ntwana
Contributor
Level 1:
New Friend:
Cheetah:
Answers
66
Questions
Helped
18417
Points
83
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on Mar 23, 2008
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Anonymous
  • 62 Answers
  • Posted on Jul 30, 2008
SOURCE: Error code H4-01
This mean you have low temp. on heat lamp 2 program interput clear interrupt 14 print may clear this code. if not you can look at the fusing unit and reset thrmo breaker that may be pop off.
Anonymous
  • 95 Answers
  • Posted on Apr 23, 2009
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Everett Lin
  • 990 Answers
  • Posted on Apr 28, 2009
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Anonymous
  • 87 Answers
  • Posted on May 09, 2009
SOURCE: error code H5-01
HI.H5-01
it shows there is some problem in exit sensor .it is in fuser unit.may be its lever is broken .
sensor is dirty clean it
check lever home position and its movemment
check its cable
reset this code
press ,p,*,clear,*
screen will go dead press 14 ,start code will bi reset
never forget to rate the solution.MIAN AKHLAQ
Code #H4-01 is displayed on the screen of my Sharp AR-M257. What does this code mean and how do I fix the problem?
Your fuser is not warming up. Try clearing with Sim code 14. If the problem comes back, one of your 2 fuser lamps is broken or your thermistor is covered with toner.
1helpful
2answers
Code H5-01 on Sharp AR-M450N. Cleared jam. How do we reset? Thanks
H5-01 is repeated jamming in the fuser unit, please check you have removed all paper from the heat section. press P/# * C * then 14 and copy start and follow the instructions on screen to reset.
5helpful
5answers
Call for service: h4-00
H4-00 means thst the copier isn't warming up quickly enough. Try this code to reset it. Press the following buttons in this order: #, interupt, C, interupt, 1, 4 . machine will say sim 14 trouble clear are you sure. Press the OK button. This should reboot the copier. Most likely the machine is in need of a heater lamp in the fuser unit.
Sharp AR-M450N+ Code: H2-01
Hello sir; You may do a reset simulation; press "p" "*" "clear" "*" enter 14 press start enter 0 press start , machine will go back to working condition.
2helpful
Code H5-01 indicated from the screen
H5-01 Exit sensor problem try to reset with simulation mode Press "Program" Press "Interrrupt: Press "Clear" Press "Interrupt" enter 1 & 4 then Press "Start"
4helpful
2answers
WHAT DOES THE CODE BELOW MEAN
H5-01 means the machine has had a jam in the same place 5 times in a row.
11helpful
2answers
Sharp AR 250 with error code H5-01
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
67helpful
13answers
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
6helpful
6answers
3answers
Ar-c160
Make sure there is no paper jammed in machine, H5-01 means 5 jams same location. Use quality paper not recycled and make sure it is fresh not old stock
PROGRAM INTERUPT CLEAR INTERRUPT must be SUPER FAST then 14....WILL RESET CODE
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
