Question about Samsung Star GT-S5233 Cell Phone
How do I turn on the pedometer on my new samsung s5
It was working for about 3-4 days but now I cant get it to count the steps
  • 3 Answers
The Pedometer is found under the S Health App. If the Pedometer has been turned off, there is an option to Start at the base, if it's active it will have a Pause option. I'm presuming your just need to hit Start to get it working again.
Posted on May 13, 2014
Good afternoon, My 4202 pedometer does not show accurate number of steps even when I actually count the step while walking. Some day it's fine, but most days it's way lower that what it should show.
well, all your steps are not measured exactly the same... from hour to hour.. they are different. and hen even more from days to day they are different. your mood is different thus having an effect on your strides. so unfortunately any step machine can only guesstimate your steps. I suggest reviewing the setup you used to measure each step.. and go thru that again... you might need to re-enter the your step size. I really hope that helps.
Aug 11, 2016 | Exercise & Fitness
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
How do i turn on mt pedometer on my samsug s5
dude just re-install this app from google play and use updated version.
May 08, 2014 | Samsung SGH-S5230 Cell Phone
I cannot get my pedometer to count steps. I was able to set up the pedometer, I can work the stopwatch, but cannot get it to start counting steps.
Oct 06, 2010 | VIA Balance 50003 Via Step Pedometer...
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Reebok B 2 pedometer
    1. Reset pedometer by pressing the reset button.
    2. Find a long open place and take 20 steps with the pedometer
    closed.
    3. Check the number of steps the pedometer counted. It should be
    between 19 and 21 steps.
    4. If the count was not right, try to move the pedometer forward
    (toward your belly button) or back (toward your hip) on your
    waist.
    5. Repeat this until you get the best count of your steps.
    6. Once found, place your pedometer in this spot each day.
    Apr 24, 2009 | RTO Reebok CS-1 Pedometer
    I am having problems with my Pedometer. What should I do?
    Review the following questions for common pedometer troubleshooting: a) Where are you wearing the pedometer? Make sure you are wearing your pedometer correctly by following these steps: * Clip your pedometer to your waistband or belt, directly above your knee. * Be sure your pedometer is perpendicular to the ground, not angled or dangling from your clothing. * Do not wear the pedometer on your shoe, sock, pocket or wrist. It will not provide an accurate reading. * Test the pedometer for accuracy by setting the step counter to zero and walking 50 steps. Check the display. If the reading is between 45-55, your step counter is functioning properly. If it reads more or less, reposition the counter on your waist and check again. * Your pedometer may give inaccurate results if you have had recent surgery or knee, leg, or foot problems. You may be favoring a leg or foot while walking. b)My pedometer has a clicking or loose part sound? Is it broken? No, a clicking or loose part sound is not an indicator of a broken pedometer. Every pedometer has an arm or pendulum inside of it. This is what counts the steps. The clicking noise that can be heard when the pedometer is shaken (or when you are walking) is the pendulum. c)The reset button will not work. The pendulum inside the pedometer is linked to the step counting device. The pendulum may become immobile from time to time, and this can prevent the reset button on the step counter from doing its job. If pressing the reset button a few times does not clear the display, here is what you can do to release the pendulum: * Give the pedometer a few gentle shakes while keeping the reset button held down. This un-sticks the pendulum. * Release the button. If the display has not cleared, press and release the button one more time. * If the display does not reset after trying this once or twice, call Customer Service.
    Dec 01, 2008 | Gaiam Walking Fit Kit Pedometer...
    Samsung Star GT-S5233 Cell Phone Logo
    56 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Fotis Papastamatiou
    Bill Long
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
