Question about Polaroid Televison & Video
Why is my polaroid 22 inch TV DVD combi not working?
When i try to change the channel it freezes on the channel and goes to a black screen.And only one channel works because it was the last channel i was watching before it broke.
  • Montel Williams
    Montel Williams May 08, 2014
    i tried resetting it and that did not work nor did turning the tv off and on or unplugging it
    Filmmaker:
    Uploaded 5 video answers.
  • 181 Answers
Hello, it sounds like the main board has gone bad (the tuner is mounted on the main board). The cost of the board replacement may be close to the cost of a new set. You may want to explore that option....tks....Terry
Posted on May 25, 2014
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Posted on Apr 28, 2008
  • 1779 Answers
SOURCE: black out
Try turning off the Closed Caption..
Posted on Feb 14, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
SOURCE: 42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Posted on Aug 22, 2009
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
The power for my bush tv model number led26982hdt
My bush television wont turn on from standby? - Ask Me Fast
www.askmefast.com > Consumer Electronics > PlayStation > Wont
Hi my bush tele wont turn on it just keeps flashing at me standby light i ve changed the fuse .... Bush 22 inch tv dvd combi keeps restarting remote doesnt work.
22" bush tv wont turn on - The Student Room
www.thestudentroom.co.uk > ... > Sound and vision
The Student Room
Mar 12, 2012 - 12 posts - ‎7 authors
i got a new tv in january from argos and not had a problem with it until now. The problem is that it just stays on standby and wont turn on. the ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
Hello my bush 22 inch tv is messed up Say if i go on it one day it..... it wont turn on from the power botton on the back not from the control ...
Jan 10, 2016 | Bush Televison & Video
How do I fix?
Sounds to be a firmware corruption. Update its firmware with latest version than it have now. Gopakumar Gopalan Google
May 09, 2014 | Polaroid Televison & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
I need the code for polaroid tv with asda remote control model no:urc20-d1f
I just bought a Polaroid 22 inch LCD DVD Combi,, I struggled for hours trying to find a code online,, and eventually researched that my Polaroid TV is made by Phillips,, I entered a Phillips 4 digit code (0081) and it worked.. I also found this link very helpful,, I used the 4 digit code routine. http://www.rtv.co.uk/remote_codes_for_sky_dig_remote.htm
Oct 14, 2010 | Televison & Video
My TV freezes instantly when it turns on.
Take the tv aparts cleans all parts and disconnect an reconnect everythings.It will work,or u might also need to replace the Video ic inverter board.
Aug 23, 2009 | Televison & Video
Black out
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Black box comes up on tv screen
The black box is a text box for closed captioning. Some stations send the signal which turns on the box while not actually broadcasting any text. Go into your setup menu and turn off closed captioning, or at least change it to a different mode. The easiest option is to restore factory presets.
Nov 28, 2008 | Polaroid FLM-3732 Television
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
109 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
