Question about Konica Minolta Bizhub C220 Color Copier/Printer/Scanner
Changed to a network and the printer is very slow at printing. It does not matter format printed (pdf, msword, xcel, jpg, etc.) Printing is extremely slow on the Konica Minolta Bizhub C220.
If printing multiple pages, it will also only print two pages at a time. It will then spool for sometime and print two more pages. All printing is extremely slow.
You can try updating the firmware
Posted on May 13, 2014
2 Suggested Answers
sladdin810
  • 3 Answers
SOURCE: How can I print full bleed on konica Minolta C451
Hi, unfortunatley you cannot print full bleed on any printer that uses toner. The way to do it is to print them on A4 Wide or A3 Wide paper and them trim them like you mentioned.
Posted on Oct 08, 2012
Why is my HP Designjet z5400 only processing a PDF but will not print it without an error message coming up?
First of all, can your so called pdf open in Adobe Acrobat Reader, if not, then you need to first convert your JPG into a PDF. You need a program to do this. But if you can open it in Reader, then you need to print it from there. Try one of these solutions.
Jul 03, 2015 | HP Designjet Z5400 PostScript Inkjet Large...
How to solve the problem of undesired changing size of printing only in PDF file formats?
If you're saying this happens to PDF's you download from web sites the only thing I can suggest is to uninstall and reinstall Adobe Acrobat, as something has gone horribly wrong with it. PDF stands for portable document format, it's sole purpose is to transmit documents in a way that always prints the same. If it's not doing that, it's broken.
If these are PDF's you are creating, by "printing" to a virtual printer that generates PDF, there's some issue with that virtual printer software's settings. Without knowing what it is, I couldn't guess. Try PDFMachine by Broadbear Software, it's excellent.
Jul 18, 2014 | HP Color LaserJet Pro 200 M251nw
How to solve the problem of undesired changing size after printing only in PDF files?
You should see the PDF as a picture. Nothing can be changed (unless you have permission)
Most of the time when starting the print job, the menu gives you some options to educe the size of the page or print to fit the page in the printer.
I hope this helps?
Reverse page printing with canon lbp3100
i think that option in not present in that printer
Apr 13, 2014 | Canon LBP 3100 Mono Laser Printer...
Memory overflow
try printing a different file format. is teh printer connmected via network or USB? connect either way and see
Apr 09, 2013 | Oki Brand Oki 62435103 C330dn Laser...
Scanning document in PDF format
To scan in PDF, you must have a PDF scanner please download and install a program like scantoPDF or others that you can use, like, NitroPDF, or Adode Professional, Either that or you can simply convert the JPG, to a PDF, with a printer, a virtual printer that "Prints" PDF, as PDF is a printing format, and it is done in software. So there is Print2PDF, PDFPro, and many others that will scan and print also you can get a PDF plugin for MS WORD as well.
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=scan+to+PDF
above is your link for scan to PDF & Below is the Print to PDF.
http://www.google.co.nz/search?num=100&hl=en&q=print+PDF&aq=f&aqi=g-c1g1g-c8&aql=&oq=&gs_rfai=
May 24, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How can I make my printer print only in black also print what I want on a page
Printing in black is no problem.
Depending on what Operating System you are using - you will need to select print in gray scale in the printing preferences menu.
Normally the printer will only print what is on the page as seen in the output of the application. You can select the pages you want to print by selecting either current page or page numbers, eg, 1-5 or 1, 2, 4 etc.
If you want to print only what you want on a page then you will need to cut and paste the bits into a new MS word document (provided the output of the application allows cut and paste). You can do this with MSWord pages and IE and PDF pages to an extent.
May 08, 2010 | HP Office Equipment & Supplies
Printing VERY slow for PDF documents on DP-8045
well if you really needed a pdf printing concern, you may add an option which is Multi Page Description Language Controller Module. the post script printing language will be activated and you won't have to wait for the computer to process the pdf document on a gdi format (microsoft). what's more is that your mac computer can also directly print to the dp-8045.
that's it
Apr 30, 2010 | Panasonic DP-8045 Grayscale Copier
Jpg format images are not poper printing in image runner 400
OPEN THE IMAGE IN MSWORD. SEE IT IN PRINT PREVIEW AND THEN PRINT
ALSO TRY
1. USE GOOD QUALITY PAPER & DONT KEEP PAPERS OPEN AS THEY MAY ABSORB MOISTURE
2. CLEAN TOP GLASS WITH COLIN OR OTHER QUALITY PRODUCT
3. CHECK THAT TOP COVER IS GIVING ENOUGH PRESSURE ON YOUR ORIGINALS
Sep 21, 2008 | Canon imageRUNNER 400S Copier
Konica Minolta Bizhub C220 Color Copier/Printer/Scanner Logo
197 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
