Question about EliteGroup K8M800-M2 Motherboard
Where can i get the manual jumper install guide
    Renaissance:
    An user who is expert in 3 categories / brands.
  • EliteGroup Master
  • 2,226 Answers
Http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx go to download ok
Posted on May 09, 2014
How do I reprogram a remote for a stannah model 260 curved stair lift
call tech support for it should have number on the manual
Apr 27, 2015 | Miscellaneous
Bios password removal.
yes, but if you removed battery that is the same as the jumper.
Mar 08, 2015 | Computers & Internet
Manual for wd 3200js-00pdb0
Here you are,
http://support.wdc.com/product/install.asp?wdc_lang=en&fid=wdsfCaviar_Blue
On the above Western Digital Support page;
1) Quick Install Guide
2) Jumper Settings
TIP:
There are NO user jumper settings. These settings are for the factory. Set as it came out of the box is the way to use it.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 16, 2011 | Western Digital Caviar SE WD3200JS...
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Bios password, how do i remove it. I need to change the boot system to install windows.
Unplug the power cord from the power supply.
The fastest way to clear the bios password would be to first find the bios/cmos battery on the motherboard. See the picture below.
Next find the 3-pin bios jumper. Asus motherboards usually mark the motherboard bios pins as, CLRTC.
It will be rather close to the bios battery. Pay attention to the current position of the bios jumper. It is currently set as normal. The jumper will cover pins 1 and pin 2.
Remove the jumper and place over pins 2 and pin 3. Doing this will clear the bios and will reset all bios settings to DEFAULT. Grab a small flat- head screw driver. Gently insert the screw driver slightly under the battery edge to help you to remove the battery. Wait 30 seconds and reseat the battery. Reset the bios jumper back to pins 1 and pin 2.
Reconnect the power supply cord. You will need to enter the bios and re-configure all your settings. Use your motherboard manual to help guide you through all your bios settings. Next time include the model number of your Asus MB.
Happy holidays!
Mike
Dec 19, 2009 | ASUS Computers & Internet
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
Wiring with another 3-way switch, works when other 3-way switch is on, clicks on/off when other 3 way switch is off
When installing a digital timer switch into a 3-way lighting circuit, you typically have to install a jumper wire across the "travelers" on the 3-way switch at the other end of the circuit, in order to get the timer to function properly, otherwise the switch operates erratically, as you've experienced
With an Intermatic brand timer, the jumper is included with the timer switch, usually it will be a small, about 2-3 inches long wire with fork terminals on each end.
You should have the power turned off before installing the jumper. Also, there is a distance limit (75-80 feet of wiring) as to how far apart the two (2) switches can be from one another, in order for the timer to work (with the installed jumper).
Normally, the travelers are one the same side of a 3-way switch, but you can use a voltage detector to confirm which wires are which (prior to turning off the power) to make installing the jumper easier. If you contact the manufacturer of your particular timer, they can email you a owners guide/installation pamphlet that shows the proper installation procedures for your timer switch.
If want, you can use the link below to contact Intermatic to get a spare users guide for your particular timer.
http://www.intermatic.com/products/timers.aspx
Hope you find this Very Helpful and best regards!
Sep 06, 2009 | Intermatic Inc. ST01C Digital In-Wall...
Jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
Apr 24, 2009 | Computers & Internet
Reset A Bios of Asrock mother board
go to the following site
http://www.asrock.com/mb/manual.asp?Model=K7S41GX&s=462
download the user manual(not quick installation guide) and check page no 7 or content 1.3 to get the jumper pins to reset the motherboard.
just short those pins and the cmos settings will be gone.
another simple method is just remove the battery and wait for 5 min and again plugin the battery.
thats it you motherboard is resetted to factory settings.
Apr 21, 2009 | Asrock K7S41GX Motherboard
MOTHERBOARD wont boot up
verify that when you mounted the motherboard you placed all the mounting screws in the right places one misplaced screw and the charge sent through your motherboard will be pushed out and dispersed into the case
Aug 06, 2008 | ASUS A8S-X Motherboard
EliteGroup K8M800-M2 Motherboard Logo
54 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
