Question about Pelco 300 SERIES 19 INCH FLAT PANEL LCD MONITOR PMCL319 WITH MULTIMODE FUNCTIONALITY
Pelco pmcl319 power supply - Pelco 300 SERIES 19 INCH FLAT PANEL LCD MONITOR PMCL319 WITH MULTIMODE FUNCTIONALITY
2 Suggested Answers
  • 43 Answers
SOURCE: Dark Screen, high voltage pcb defective, no CFL illumination
replace the transister Q7.
Posted on Mar 17, 2010
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Dec 05, 2014 | Pelco PEL-PMCL542A-S 42-Inch Liqued...
I have a pelco pmcl319 19" lcd monitor. when i switched it on the power (LEDlit) stays blue but it has no display. hope you have a solution for this. thanks.
First thing I would recommend is to get a flash light and shine on the surface of the screen where the Pelco name normally appears when first turned on. Next press the power button and watch at the center of the display. If you see a gray image of the Pelco name then the ccfl backlighting is no longer functioning. I have been able to order replacement ccfl lamps and if need be inverters that drive those lamps. These part can be purchased from http://www.lcdparts.net/. Disassembly of the LCD display is required as well as some soldering.
Feb 17, 2011 | Pelco 300 SERIES 19 INCH FLAT PANEL LCD...
Turned off and on, Now no power, happen to ten monitors at once
Commonly there are 2 defective capacitors near the switching transistor located on the power supply PCB that fail causing a no power issue. After replacing these capacitors power on and check operation for any further issues.
Oct 29, 2010 | Pelco 300 SERIES 19 INCH FLAT PANEL LCD...
I have a Pelco ES30CBW35. Rewire the 230V/115V switch and transfo
this manual should help
  1. [PDF] Pelco EH3500 Series Environmental Enclosure_service manual
go here and down load it you'll need adobe reader to view it but, you can get it for free. Best of lock Rich.
Oct 23, 2009 | Pelco ES3012 5MLZ30W Esprit High Res Black...
Pelco Spectra III PTZ camera wrong fuse?
It is replaceable, as long as no harm has come to the rest of the camera.
Mar 14, 2009 | Pelco SD53C22 Smw 0 Spectra III Se White...
Power went out now my pelco kbd300 isnt working
If no power, it must one resistor of power interface circuit burnt. you need to send it for repair.
if it can be powered up, just can't cotrol. you can try to press the key of F5(AUX OFF), and powered it and hold "AUX OFF" for more 3 seconds and release. this mothod is used for calibrate the joystick.
Mar 12, 2009 | Pelco KBD9000 Keyboard
Computers & Internet Logo
48 people viewed this question
Top Pelco Computers & Internet Experts
David Payne
David Payne
Are you a Pelco Computer and Internet Expert? Answer questions, earn points and help others
