Question about Acer X203H bd Monitor
Monitor to cable box issues.
I've tirelessly searched the internet for an answer and the specs say it should work. I cannot get into the menu of the monitor since the error message is up. If I unplug the cord it says 'no cable connected'. I'm not sure if there is something in the menu of the monitor that is the problem (do I need to hook it back up to a computer?) or if it's the compatibility. People do this every day though so there should be a way for me to do this.
    Scholar:
  • 82 Answers
Can you provide a bit more info like type of cable box, type of connection you are using (hdmi or something else?) and does it work with a TV?
Posted on May 08, 2014
Testimonial: "The cable box works fine with a TV. It's a Charter Communications hd cable box."
Tip
Start Menu tips in windows 7
Start Menu tips Many people overlook the Start Menu, rarely using it except as a jumping off point to run an application or get to the Control Panel. But there's actually plenty you can do with it.
Search the Internet from the Start Menu Note: This tip relies on the Group Policy Editor, which isn't available in some versions of Windows 7. Thus, this tip will not work if you have the Home Premium, Starter, or Home Basic editions of Windows 7.
The Start Menu's search box is a convenient way to search through your PC -- but you can also have it do double-duty and perform Internet searches as well. To enable this feature:
1. In the Start Menu search box, type GPEDIT.MSC and press Enter to run the Group Policy Editor.
2. Go to User Configuration --> Administrative Templates --> Start Menu and Taskbar.
3. Double-click "Add Search Internet link to Start Menu," and from the screen that appears, select Enabled. Then click OK and close the Group Policy Editor.
4. From now on, when you type a search term in the Search box on the Start Menu, a "Search the Internet" link will appear. Click the link to launch the search in your default browser with your default search engine.
on Jan 12, 2010 | Computers & Internet
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
Black horizontal lines across entire screen.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Dec 08, 2012 | LG FLATRON W2252TQ-PF 22" LCD Monitor
Have a nx1932w; worked fine until this morning; turn on the monitor (using it as tv) the logo is in black and white and it says no signal - can't even get menu button to work.
the most common problem with LCDs today is failing electrolytic capacitors, especially in the power supply section. Look for bulging, leaking, blown or missing capacitors and replace them.
May 17, 2012 | ViewSonic NX1932W LCD Monitor
Samsung Syncmaster 2333
Check signal cables means there's no signal on input. If your PC still shows up on a different monitor then it's a time to replace a mainboard in your monitor.
Jun 03, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
My pc was working properly when I turned it off. Upon returning I powered up my pc (HP 805n) but it will not turn on. The green light in the back of the pc is steady, but no response. I've own the pc...
to trouble shoot,
open case and disconnect all cables except power supply.
if the computer starts up okay, then shut down and connect the cd-rom then startup. if that's okay then connect any other cables . if any one of the parts are defective you will find the stinker.
if the computer still won't go, try another power supply/
if that's okay, then the board might be bad
Aug 03, 2017 | HP Pavilion a805n (PS519AA) PC Desktop
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Menu pop ups
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Apr 13, 2008 | Sony SDM-HS75P/S 17" LCD Monitor
Acer X203H bd Monitor Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
