How do I connect Surface 2 32 GB to TV? - Televison & Video
    Scholar:
  • 82 Answers
I think this will have a micro hemi socket for which you'll need a cable from micro hdmi (male) to standard hemi (male)
Posted on May 08, 2014
  • fkmJag May 08, 2014
    sorry i meant hdmi, not hemi :)
Why turns tv black When trying to connect?
What make model TV and wireless adapter are you using?
Oct 14, 2015 | Computers & Internet
MS surface will not turn on
1. Assume battery has sufficient charge
2. Assume no physical damage to unit, liquid, dropping etc
3. When turned 'on' can an updated OS be installed?
4. Any other faults or problems noticed?
5. Remove all peripherals and reboot
6. Go to this link: www.microsoft.com/surface/en-gb/support/warranty-service-and-recovery/surface-wont-turn-on
Good luck.
Sep 01, 2014 | Microsoft Surface RT
How do you set a resistor to 2200 ohm
Connect two resistors in serial eg 1kOhm +1.2 kOhm. You may not need exact 2200 assumung that standard resistors tolerance is 5% - check with Ohmmeter if it's between 2,11 and 2,32 kOhm. But if it's special and value is critical then get trimmer (small adjustable resistor) and adjust value to Ohmmeter indication. Watch out required power.
Mar 01, 2014 | Gardner Bender GB GMT-312 12 Range Pocket...
How do you show Windows Surface on tv?
Connect an HDMI cable from the PCtoTV unit to the HDMI connection on the TV. Then at the tv use its remote control to select HDMI sources until you see the windows surface.
Aug 18, 2013 | Cables Unlimited PCtoTV USB 2 0...
Can i connect my computer to the tv to access internet
hi rtovar062107,
The answer is no, you cannot connect you pc to the tv to access internet connect your pc to a modem w/ a cable or with wi-fi
Thx
Banaple
Sep 02, 2010 | Sony VGC-LT25E Desktops. 500 GB hard...
Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Jul 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No Sound is there while using SAA7130 TV Card
I am using p4 dual core intel processor 3.06 Ghz. Recently i installed tv tuner card on my suystem with cabil connected to this card. but due to unknown reasons sound stopped coming. though the picture is still there i am using Windows vista . My system config is 2 GB DDR2 ram and tv tuner card with 80 gb HDD + FDD
Due to this problem I formatted my hard disk and re-installed everything but the problem remained i re-checked everything with no results.
can you help me to sort out this.
thanks
Dec 29, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Cant see a movie / photos using idk-o1 dock and 160 gb i pod
just go to the setting options and turn the tv out off and it should work fine,if not reset the settings to the default.
Dec 17, 2008 | Pioneer IDK-01 Universal iPod Dock
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
