Question about Muratec F-300 Fax
I have a muratec F520, how do I clear the print drum counter...It continually displays "Drum should be replaced".
3 Suggested Answers
SOURCE: How do I reset the drum counter on a Muratec F320?
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
Posted on Dec 13, 2008
SOURCE: muratec mfx 1600 drum replaced alarm will not reset
Ignoring the Toner Empty Message
When the toner cartridge is empty, the machine shows a “Toner Empty”
message and stops printing.
You can set the machine to ignore the message when it displays and to
continue printing the pages.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button (�� or ��) until “Ignore Toner” appears on the
bottom line and press Enter.
3 Press the Scroll button (�� or ��) to select “On” or “Off.”
Select “On” to ignore the Toner Empty message.
Select “Off” to stop printing when the message appears. This is the
default setting.
4 Press Enter to save the selection.
Posted on Oct 20, 2009
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
I just replaced my Muratec F-305 drum DK 203OUS with new one and the red warning dot comes up and says "Drum near end" with the new drum. What is wrong?
Yes, the display was saying "drum near end"....it was not saying to replace the drum,... you only replace the drum when it says "replace drum"....right now you have b;own the fuse in the new drum because you replaced it TOO SOON. You will have to find someone to replace the mini-fuse in the drum cartridge...it will still be ok...but soon you will not be able to print on the machine,,,READ THE USERS MANUAL.
Nov 16, 2010 | Muratec F-300 Fax
Brother DCP 8060 is displaying drum near end what does thic mean
After approx. 25000 pages you should replace drum unit
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
To reset the drum counter, follow the instructions below:
  2. Press the Clear/Back key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Oct 04, 2010 | Brother DCP-8060 All-In-One Laser Printer
How do you reset memory board for muratec f-320 . I am trying to get rid of an error message"Replace drum unit printer not useable". Installed new drum unit and still gives the same error message.
Before doing complete Memory clear try the following...
Press..PROGRAM,*,*,I(thats the letter I),then ENTER.
That should reset it. Only replace the new drum into the machine when the machine says "Replace Drum"...NOT when it says "replace drum soon".
As a last resort a complete memory clear is PROGRAM,*,3.....but be warned this will clear all memory back to factory defaults "except" the Life Monitor which has the counters.
Oct 29, 2009 | Muratec F320 Plain Paper LED Fax
Reset drum counter on a muratec mfx 1430
Drum counter is reset by installation of a "NEW" drum.
There is a small fuse at the rear of the drum on the top( you will see the 2 brass contacts) When a new drum is installed, the fuse blows and resets the drum counter. Installing a used drum will not reset the counter as the fuse is already blown.
Sep 15, 2009 | Muratec MFX-1430 Copier
Muratec 2830 drum cartridge problem.
The drum cartridge is different from the toner cartridge. The drum has reached its life cycle and must be replaced. This is normal for any copier of that class.
The drum is not too expensive and not difficult to replace.
Hope this helps!
Sep 09, 2009 | Office Equipment & Supplies
We have a Sharp 1641CS copier and the drum light came on a few weeks ago, we replaced it, and the light never turned off, now it blinks, and the will not copy at all? Help!
If you will replaced the drum you should reset the drum counter .
To reset follow these steps:
Step1: Press continuously Clear key then press Exposure key then Clear key then Exposure key
Step2: You are inside the simulation if the display turns off but if not do again step1
Step 3: Press 24 then press print button then press 7 then print button
If not canceled try step4
Step4: Do step1 to step2 then Press 24 then press print button then press 6 then print button
Mar 02, 2009 | Sharp AL-1641CS Copier
Nov 12, 2008 | Muratec F320 Plain Paper LED Fax
Drum replacement
simulation 24 7 will clear the drum counter
Sep 25, 2008 | Sharp AL-1530CS All-In-One Laser Printer
Muratec F-300 Fax Logo
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Ben
Ben
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
