Question about Lands Phones
I have an er-5 error code that shows on my m&s system musical intercome system. what does that mean?
On my musical intercom system model mc302 (M&S Systems) that is showing a code ER-5. What does that mean?
  • 146 Answers
SOURCE: no intercom connection between handsets
Here is a link to the uniden manual link and an excerpt from the manual section which deals with your problem :
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
The handset doesn't
communicate with other
handsets.
• De-register the handset (see "De-register the Handset" on page 32) and register the handset
(see "Register the Handset" on page 68).
• Make sure that you have registered all handsets.
An extra handset can't join
the conversation.
• Make sure there are not 2 handsets already using the 3-way conference feature.
The handset or the base can't
join the conversation
• Make sure that another handset or base is in privacy mode.
To register a TCX805 handset, simply place it in the main base.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD.
When R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to
the base. If R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
To register a ELX500, TCX440, or TCX400 handset, follow the steps below:
1) Disconnect the AC adapter from the main base.
2) While pressing down flash/find hs, reconnect the AC adapter.
3) On the handset, press and hold # until you hear a beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
Posted on Jan 16, 2008
SOURCE: How do I turn off the intercom to my phone
Hi Andrew,
Press [feature] [8] [8] to prevent your phone from receiving the intercom
Brian
Posted on May 13, 2008
SOURCE: lg lrfd22850sw frige code says ER FF. what does it mean! Please HELP!!!
I had the same error code. The problem was that the fan had frozen. I defrosted the fridge/freezer completely (it was ok for me cause I have a spare fridge). Your problem possibly is a frozen fan problem
Posted on Jun 26, 2008
SOURCE: LG refrigerator error code
Had the same problem + a weird noise, which turned out to be ice build up on the blower fan. Unplugged overnight and then opened the lower back panel. There is a small fan that blows over some small coils at the bottom of the box. There is also a drip pan that should be "full" of water. I sponged out the drip pan, put the panel back on and then plugged back in. Works great.
Posted on Nov 04, 2008
cnavarro
  • 2460 Answers
SOURCE: Using intercom on Lucent partner phones
A Partner is a pretty simple system and the phones are probably all in a single calling group. Your extensions are numbered from 10 to whatever, so at the least you can grab a phone, press the intercom button and dial 0 or 10. It will ring the main phone.
From there, you can start dialing 11,12,13 etc and build your directory. IIRC pressing * in front of the number turns it into a handsfree call. Now, here's where you get to see what kind of installation you have :-) Press intercom and dial *71. With luck, every idle phone will have paging. (71 will ring every phone btw).
This does require programming and an extension can be either in or out of a group.
I do have a basic Partner ACS manual on my website. http://www.public.carl.airpost.net/Partner_ACS.pdf
The display phone users manual in in the document. Page 179 starts chapter 6, a 30 page guide to the phones.
Carl
Posted on Jan 12, 2009
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
LCD shows "Er7"
EEPROM accessing er-
ror
LCD twinkling
Device
parameter
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
http://webcache.googleusercontent.com/search?q=cache:V0KPe0jswmgJ:www.hmm.info/uploads/tx_sbdownloader/smartLAB_profi_user_manual_ENGLISCH_R4.pdf+&cd=2&hl=en&ct=clnk&gl=us&client=firefox-b-1
Dec 21, 2017 | Health & Beauty
Master Unit M&S System displays REL 5
This actually means RELS which stands for release. There is typically a bad room station that has a broken button, or button stuck. To troubleshoot, remove all black wires from the master unit. Any display of RELS or clicking sound should stop. Add back the black wires one by one until the issue of RELS occurs again. If so, do not attach this wire and hook up all remaining wires. If the user wants to know which room station this is, go from room to room and press the listen button. If the music is muted, the station is good. If the music continues, this is the bad room station. Unfortunately, these room stations are no longer available. Visit our website for replacements parts and products, or if you have more questions.
Intercom Systems
Don't forget to visit and like our Facebook page https://www.facebook.com/QualityHomeSystems
Feb 27, 2015 | M&S Systems 3- Or 4-wire Retrofit...
M&s intercom model 200 manual
Here is a link for the manual.
NuTone NM200 4 Room Intercom Kit NM200 4 Room Intercom Kit
Please visit our website if you need a replacement part or if you have more questions.
Central Vacuum Intercom and Whole House Audio Systems
Don't forget to like and visit our Facebook page
https://www.facebook.com/QualityHomeSystems/?ref=hl
Aug 16, 2014 | Radio Communications
How do I turn the intercom off at an individual handset?
Do you mean intercom or paging? You can turn off paging by setting the Paging Deny code. From the intercom dial *7211 with 10 being the allow code. As far as the intercom, onlly Do Not Disturb (*7121) will fix that (as always change the 1 to 0 to allow). The DND light will light solid and when you press the button, the display will give you information as to what is set.
Carl
Jun 16, 2011 | Panasonic KX-T7630 Corded Phone
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Toshiba DKT2020-SD 20 Button Display Speaker Digital Telephone
    To change the time, go to extension 10, while keeping the handset on hook, push intercom, then dial # 6 5 2, enter the new time ie. 102510 (hour, min, seconds), then push the redial key to save. That should do it. to set the day use the intercom # 653 code (1=Sun, 2=Mon, ect). To change the date use the intercom # 651 code (ie. 080510). If that does not do it, you may have a different model key service unit, and you will need to notate which system your using.
    May 09, 2008 | Lands Phones
    RX-V661 Receiver
    your receiver has zone 2 output which is operated independently of the main reciever. so you can have a dvd playing inthe main reciever and the tuner playing over the intercom. read about it in your manual page 89. in will hook up to 2 RCA jacks in the back Zone 2 out.
    Dec 29, 2007 | Yamaha RX-V661 Receiver
    Partner 18D intercom not working
    If you mean intercom, as in Speaker/overhead paging, then the buttons need to be reprogrammed to access the intercom. If you mean calling from one avaya phone to another, then the system is more then likely fried. from your system press the intercom button, 61. that should give you the paging access that I think you are looking for.
    May 21, 2007 | Avaya Corded Phone avaparp18d
    Lands Phones Logo
    136 people viewed this question
    Top Lands Phones Experts
    David Burbee
    David Burbee
    Are you a Lands Phone Expert? Answer questions, earn points and help others
