Question about Dehumidifiers
After the dehumidifier runs for 5-10 minutes it blows the circuit breaker
  • Dehumidifiers Master
  • 3,382 Answers
It sounds like there are other items on that circuit and the total load is a little above the circuit breaker rating. If not then probably the start relay is not dropping out.
Posted on May 30, 2014
SOURCE: trips the circuit breaker on start up
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Posted on Apr 27, 2008
  • 1619 Answers
SOURCE: My dehumidifier keeps blowing the circuit breaker.
As the unit gets older the motor will cause more load on the circut, also after years of use the breaker will trip easier. Replace the breaker and you may get more use out of the unit but most likely you will have to replace the unit.
Posted on Jul 14, 2009
heatman101
  • 43501 Answers
SOURCE: Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Apr 30, 2010
heatman101
  • 43501 Answers
SOURCE: dehumidifier keeps blowing circuit
The compressor is bad...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
heatman101
Posted on Jun 18, 2010
heatman101
  • 43501 Answers
SOURCE: when dehumidifier is turned on
Hi, Compressor is bad... tripping the breaker...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Posted on Sep 07, 2011
Pops electric panal breaker
Hello friend, thank you for your post!
A dehumidifier is similar to having another refrigerator plugged in. It is recommended that it be plugged into a circuit of its own. If you are talking about the house fuse or circuit breaker it could be the circuit has to many products plug into the that house circuit. I would suggest moving it to another area of the house to see if it also blows that fuse. Hopefully this is helpful. -Matt
Sep 13, 2014 | Dehumidifiers
Edison 40 fan starts -then trips breaker (before compressor kicks on)...toast?
Maybe..but what else do you have on the same circuit? Could be overloaded by another appliance. Make sure you unplug all items on the same circuit, then try it again. If it still blows most likely its in the unit, if if runs with no problem, issue is overloaded circui, too many other things on the smae line.
Aug 14, 2014 | Edison 40 Pint Dehumidifier
Unit will start and run for 5 seconds, then will blow a circut breaker on 20A. circut. This is a model AD75USTO Serial # QU2660438 AKA Whirlpool gold energy star
Hopefully, it's not a problem inside the unit that's causing the circuit breaker to trip. Is there another electrical appliance plugged into the same outlet or on that circuit that is ON and draws 15 amps of power? If so, that's the problem. If that's not the case, turn the circuit breaker OFF and remove the outlet cover, so you can inspect the receptacle and it's wiring. A loose wiring connection or a broken or cracked receptacle could be the issue. If you don't find any damage reassemble the outlet and turn the circuit breaker back ON. Instead of plugging in the dehumidifier, plug in a lamp or something similar and turn it ON. Leave it on for more than 5 minutes to see if the circuit breaker trips again. If it does, you'll know the problem is either with the outlet receptacle or the circuit breaker. If doesn't, plug in the dehumidifier (Make sure the Master ON/OFF Switch on the unit is in the OFF position, before plugging it in. Then turn the Master ON/OFF Switch to ON and set your controls. If the circuit breaker trips again, the problem is in the dehumidifier. You will need to call Whirlpool Customer Care, as it's an internal electrical issue.
In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201188927.pdf
I hope what information I have provided to you, will help you trouble shoot and solve the problem.
Apr 16, 2011 | Whirlpool 75-Pint Dehumidifier
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
When power on keep blowing the circuit breaker.
The compressor is bad... this pulls too much current and blows the breaker...
There can be many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 24, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifier keeps blowing circuit
heatman101
Jun 12, 2010 | Goldstar DH304 Dehumidifier
When compresser comes on blows electric breaker
the outlet that you have the dehudifier plugged into has too many items plugged in on the same circuit and when the compressors kicks in it draws more amperage than the breaker load can hold thus popping the breaker either remove some electrical apliances from that circuit load or plug in elsewhere
Sep 14, 2009 | Kenmore 54501 Dehumidifier
My dehumidifier keeps blowing the circuit breaker. It has never done this before - 3 years.
Jul 14, 2009 | Ebac HD880 Dehumidifier
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Dehumidifiers Logo
70 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
