Question about Minka F506-CB Ceiling Fan
Minka ceiling fan has only one speed - Minka F506-CB Ceiling Fan
    Genius:
  • Minka Master
  • 1,617 Answers
Probably needs a new receiver. Call Minka @1-800-307-3267
Posted on Mar 17, 2015
SOURCE: light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Posted on Feb 18, 2009
SOURCE: Minka Aire remote controlled ceiling fan
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
mcgyver468
  • 710 Answers
SOURCE: I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Posted on Apr 25, 2009
  • 13 Answers
SOURCE: Noisey Minka Aire Napoli ceiling fans
Minka fan are life time warrantied, have you tried contacting customer service... Minka fans motors have a very simply design... uninstall the fan... try balancing the fan on a table or some where that allows you to remove the shell that covers the main body of the fan... Carefully (someone that is very familiar with the electrical components.) soft wire the fan allowing you to see the motor as the blades turn... You will then see what is making the scraping noise... I may have some extra fan parts that you can easily replace... If you like to write me at payitforwardx2 @ gmail . com I am willing to try to further assist you...
Posted on Apr 23, 2010
SOURCE: Minka Aire Como F603 - Light bulb burned out
I found the Manual to the F603 in pdf format at: http://minkagroup.net/Admin/UploadFiles/F603-English.pdf It describes how to put bulbs in so it was simply a matter of reversing the instructions to get the old ones out. However, it is not that easy to get the bottom section off so one has to be careful or you will twist the whole unit instead of just the bottom part..... I think what you did was push up too hard and then turn the whole unit. Try pushing up firmly but at the same time hold some fingers (or have someone help in this) on top of the bowl above the fan blades and then twist counterclockwise an inch or two and the bottom part will release (don't let it fall). Then you have easy access to the bulbs. Good luck.
Posted on Oct 08, 2010
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
Dec 27, 2009 | Minka Aire Ceiling Fan
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Minka Aire Como F603 ceiling fan - light bulb replacement
Try Googling (Minka Aire)(F603)(manual) without parens for instructions.
Jul 28, 2017 | Minka F603-WH Ceiling Fan
Dryers Logo
94 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
