Question about Electrolux EDW7505HPS Dishwasher
Why is there water in the bottom - Electrolux EDW7505HPS Dishwasher
    Scholar:
  • 82 Answers
I had this problem and it was due to waste food in the outlet pipe at the bottom. you can usually remove the filter and clean it.
Posted on May 08, 2014
Why do I have to have an external feed at bottom?
Having the dip tube routed to the bottom will keep the water circulating in the tank. Drawing out from wither the top or bottom will make no discernible difference.
May 02, 2015 | Water Water Heaters
Hot water bypass
On the back side of the water heater you should see a water line connection at the bottom and one at the top. There should also be a water line connecting between the top and bottom lines. The bottom is cold water input and should have a valve. The top is hot water out put and may or may not have a valve, depends if there is a check valve installed. and the connection line between the two will have a valve. If you are wanting to bypass close the top and bottom valve and open the middle valve. If you are wanting to use the water heater, open the top and bottom and close the middle valve. Open the Hot Water on your kitchen sink and wait until you have a steady flow of water before you turn on the water heater.
Jul 11, 2014 | Keystone RVs
We have side by side Kenmore and on freezer side we are getting prozen water under the slide out drawers on the bottom on interior. We have cleaned it out and it refreezes and when we turned off water to...
Your drain line is frozen and not allowing the defrost water to drain to the pan below. The drain hole is at the bottom of the evaporator coil in the freezer behind the metal rear panel. You may need to remove the panel to access it. You can use hot water to thaw it out and you should be in good shape.
Kelly
Mar 24, 2011 | Kenmore Side by Side Refrigerator
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a forty gallon electic rheem water heater with a pipe going in the bottom and one in the top which wone is the cold water inlet the bottom????
The one with the pipe going to the bottom is the cold...cold water goes in on the bottom and the hot comes off of the top...hot water is lighter then cold water and rises to the top...
heatman101
Oct 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can you tell me if the top inlet is the in water from the other filter i have and the lower inlet is the out water or have i set it up wrong
Water should normally go into the top of a filter and out the bottom.
Your pump should be sucking water from the body of water, through the pump, into the top of filter #1, out the bottom, into the top of filter #2 out the bottom back to the body of water.
Alternatively, the water may be coming from the body of water into the pump, into the top of both filters at the same time, out the bottom of both filters and back to the body of water.
Water SHOULD NOT go into the bottom of the filter when running in filter mode. If this is the way you have it, all the junk you filter from the pool will be stuck in the laterals and the sand in the bottom. You will never be able to clean (back wash) the filter.
If your filters are DE or Cartridge, the same idea applies.
I hope this has answered your question.
Thanks for your interest in FixYa.com
May 26, 2010 | Garden
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
Electrolux EDW7505HPS Dishwasher Logo
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
