Question about Atlantic Technology System 170 System
Home Theater Subwoofer rattles
My Quad L-Subwoofer rattles systematically after 20 minutes even if the LFE cable is disconnected and without any other connection.
It began this after I played with the settings (phase, volume and crossover). I reset the volume to normal 50% and the problem continues.
The HP isn't broke, I opened the subwoofer and briefly checked the amplifier northing is broken in appearance.
  • p48110 Jun 28, 2009
    Sorry no knobs on this subwoofer all settings are made trough the Remote Control. With a spray of air on the amplifier cards, I first succeeded to create more crackles and this without any wait time.
    Removing one connection, coming from the front panel apparently, it stopped the crackle completely but the soud too. I replaced this connection carefully and it works almost good, after 2 hours I heard a little crack. I'll continue my listening tests.
    President:
  • 1,114 Answers
Sounds like the controls have a buildup of dust on them and creating a magnetic charge and thus noise. Radio Shack sells "Tuner wash" Use it sparingly, it only takes a little, then work the controls back and forth for a few seconds and turn back on. You may have to do this a couple times to fully clean the potentiometer (vol control) (crossover control) Take the knobs off the unit before you spray it. If you have a high gloss finish on the sub, put a rag around the control to keep excess wash off the plastic. It will varnish a gloss finish. Just use it carefully. Hope this helps
Posted on Jun 23, 2009
I wish to replace a subwoofer on a surround sound system
In most surround sound systems the sub woofer is powered separately and uses a standard RCA coax connection to the receiver/amplifier.
Replacing is simply plugging in the new and reconnecting the coax cable.
Usually the audio signal is Dolby Digital 5.1 the (.1) is the LFE Sub-woofer. The connection is between the Subwoofer RCA connector on the amplifier and connects to the (LFE-Line) in on the subwoofer speaker.
Hope this helps?
Aug 09, 2016 | Audio Players & Recorders
How do i connect my subwoofer to my home theater
Easy. Your home theatre amp will have a sub or LFE output ( RCA plug ). You simply connect this output to the input ( usually the left side, or use a Y splitter and use left and right inputs, or the LFE input if your sub has it ). Then, you must turn the sub on in your recievers setup menu, and your sub should work.
Mar 03, 2013 | Sunfire True Sub MK II Subwoofer
I have a sony HTDDW7600, i cannot get the dedicated subwoofer amp to work. The fan is running on it, but for some reason the only way i can get it to do anything is to unplug the cable that goes from the...
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Sony MUTEKI HTDDW1600 Theater System
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I have a pioneer home theater receiver with a sub out.....my sub is a paradigm with red and white inputs. all of the subwoofer cables im finding are sigle cables, so do i need a y adapter or not?
Some specific model numbers would REALLY help.
And referring to the Paradigm manual might tell you if one or the other input is usable solo.
Or you could just get a common RCA splitter and share that LFE input with both.
Mar 08, 2011 | Audio Players & Recorders
Can i put an extra sub woofer on my lg da3525 via the woofer out socket and what plug do i require to do this
How to Connect 2 Subwoofers to One Receiver
Subwoofers produce the deep bass sounds that give home theater the realism of being at the movies. A good subwoofer can rattle the walls during action sequences, while adding depth to recorded music and a heightened sense of feeling in the midst of a televised sporting event. Because most home theater receivers are equipped with a single subwoofer jack, connecting a second subwoofer requires a simple audio adapter available at electronics stores. Self-powered subwoofers have their own built-in amplifiers to drive the bass speakers, so they cannot drain power on the main receiver in a system and thus pose no danger to the equipment, even when an extra subwoofer is connected.
Things You'll Need:
Home theater receiver
Y-adapter with RCA jacks on two ends and an RCA plug on the other, available at electronics stores.
2 RCA subwoofer cables
2 subwoofers
Instructions
Plug the Y-adapter into the home theater receiver's "Subwoofer OUT" jack.
Connect an RCA subwoofer cable to each jack on the Y adapter and route the cables to the subwoofers in the room. Because subwoofers deliver an omnidirectional sound, the boxes can be placed anywhere they won't get in the way, but within reach of an electrical outlet..
Plug an RCA cable into the "Sub IN" jack on the back of each subwoofer.
Connect the subwoofers to wall outlets and turn on each unit by pressing the power button, typically located on the back panel.
Adjust the volume and crossover settings on each subwoofer as desired. The crossover adjustment knob tells the subwppfer which low-end frequencies to reproduce from the audio signal, such as a movie on DVD. All frequencies higher than the crossover setting will be transferred to the other speakers connected to the receiver.
Tips & Warnings
Use subwoofers that are closely matched in power, as rated in watts, when using two subwoofers in a home theater setup.
Disconnect the subwoofers from the power supply while making the audio connections.
Have a nice day...
Feb 19, 2011 | LG DA-3525 Theater System
Do I really need a powered subwoofer?
Many people believe that a powered subwoofer is only necessary if you are using small bookshelf speakers. While a powered subwoofer main purpose in home theater is to reproduce the Low Frequency Effects (LFE) channel. This channel (the ".1" in a "5.1" or "7.1" recording) was introduced with Dolby Digital and DTS and offers a completely unique conduit for low frequency information and effects.
The LFE channel dramatically improves the impact and emotion of scenes in all types of movies. Imagine missing out on the resonance of the approaching T-Rex in Jurasic Park, not feeling the rumble of an earthquake, or missing the low tone that penetrates your body just before the bad guy jumps out at you in a scary movie. Emotion is often conveyed through a movie's soundtrack and a powered subwoofer makes the most impactful low notes really hit home. Invest in a good powered subwoofer- you'll be glad you did.
Aug 15, 2010 | Coby Audio Players & Recorders
Aug 12, 2010 | Audio Players & Recorders
No Soound on Subwoofer from Yamaha RX-V363
I have the same setup. Are you going out of the subwoofer output of the reciever? (it's purple.) then into the LFE jack of the subwoofer (also purple.) That's the only connection you need besides power. If you have those right, try using your cable for something else to make sure the cable is good. Is the indicator of the subwoofer green? Mine comes on with the reciever. Good luck!
Mar 31, 2009 | Yamaha RX-V363 Receiver
7.1 channel onkyo home theater -- no sound out of subwoofer
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Nov 25, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Atlantic Technology System 170 System Logo
184 people viewed this question
Top Atlantic Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Atlantic Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
