Question about Electrical Supplies
Removed one end of a three way light and indtalled plug. Tied red and black at plug and it works. When I turn light sw on, plug goes dead?
Do I need to eliminate red wire?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
Turn the switch the other way around? without knowing how it was originally wired, it's a little tough to diagnose.
Posted on Jun 01, 2014
  • 5,089 Answers
Do you mean you replaced one 3-way switch with outlet?
http://waterheatertimer.org/How-to-wire-switches.html#3-way
Instead of replacing 3-way switch with outlet..
You can use a Leviton 5245 combo 3-way switch and outlet
http://waterheatertimer.org/How-to-wire-switches.html#5245
Gene
h
Posted on May 26, 2014
  • 417 Answers
SOURCE: Downstairs toilet light switch needs rewiring
Yes, run a black wire from connector (a) to one terminal of your new light fitting if you are installing a metal fitting you will need to connect an earth wire also.
If you are reusing the same pull switch and it is still connected as you describe then the floating end near the light is probably the switched live conductor, so you could connect this to the live terminal of the new light. but be careful it may be live.
Caution always disconnect the power before working on electrical wiring.
Please remember to rate this solution.
Posted on Dec 07, 2008
  • 8404 Answers
SOURCE: I am trying to replace a rotary canopy switch in a
This is a very strange arrangement, your switch
BTW, my pleasure ... I am a volunteer poster here - not an employee. I'm at home ... watching Dancing with the Stars - I do this for the 'bragging rights'. I'm not perfect but pretty darn good for a High School shuv-out!
You may be able to find a "Off - On (1) - ON (2) - Off" kind of switch ... I'm racking my little brain from when I worked as a (50 year+old) stock boy at the Ace hardware/Auto supply, row 3 - electrical - to see if I remember seeing that switch. I'm pretty sure there is such a thing.
Your arrangement is very strange. Take your switch to the hardware and spend some time exploring. And forget the big box store for now ... look at your little hardware store first. I think they will most likely be able to find you a replacement or the switch I described above.
Thanks for using Fixya.com and I hope I have helped you with your question.
a
Posted on Oct 20, 2009
Testimonial: "Good advice. Made me not feel so bad about being puzzled by this situation."
SOURCE: My girlfriend has a leviton illumatech IP106 that
As a general rule for timers and dimmers:
The Black dimmer wire connects to black hot wire coming from breaker (122V line)
The red dimmer wire connects to Load (wire going to chandelier)
The wall red wire that is capped could be a couple different things. a) It could go to a second switch that was used to control the chandelier. b) it could be another wire that goes to same ceiling box as chandelier to be used to control a fan, except you don't have a fan. In the second case, if you install a fan with a light, you could control fan and light separately.
The green is a ground wire that connects to bare copper wire in box. The bare copper connect back to main breaker box on the Neutral busbar.
White wires that are twisted together inside your light switch box also connect back to to main breaker box on the Neutral busbar.
The ground wire and neutral are a redundant safety system to protect you from electrical devices and appliances that have 'shorted'
The black hot wire connects back to the circuit breaker.
For example, each circuit breaker controls one area of household lighting. The black white and copper wires leave breaker box in a single romex cable. The romex travels to a junction box in the area where the lights are located. The junction box is usually a switch box or a ceiling box. From the junction box, the romex travels to each other switch, light and receptacle box in the area. So each box has 1 hot and 1 neutral and 1 ground that is connected in a line that leads back to breaker box.
Here's a couple pages that make home wiring easier to understand:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Install-owb.html
Posted on Oct 15, 2010
Testimonial: "Thank you for the excellent advice!"
heatman101
  • 43501 Answers
SOURCE: I am replacing an existing
White wires under the silver screw...
The black wire under the black screw...
and the red wire under the brass screw...
If it does not work right then switch the red and black wires...
heatman101
Posted on Apr 20, 2011
SOURCE: I have the same problem
You have 120volt photocell.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Wiring sounds correct.
Lights are on all the time, even in daylight.
How is the power by-passing the photocell shut-off?
Disconnect ground wire to make sure there is not a ground fault causing circuit to complete on ground wire.
Otherwise the photocell might be bad.
Posted on Aug 22, 2011
Overall I have a switch at each end of the garage with two lights in the roof in between. Sw (A), Lite (B), Lite (C), Sw (D). SW A & D work as three way. I want to change out Sw D to a wall plug a
If this is what you've got:
"S3" are 3 way switches, black screws are the common or shunt. (Adjust colors of wires to what you have).
You can easily change it to look like this:
All S3s are out. Replace one with an S1 (single pole). The other S3 is now the outlet. Silver screw for neutral gold screw for hot. Outlet is always on, S1 controls both lights.
Please note: There are several ways to wire 2 three way switches (S3) to control a light or two. This is just one with a way to change this method to the way you're look for. Your wiring may not allow you to do this as easily.
May 08, 2014 | Electrical Supplies
Own a Heath zenith sh 5105 motion detector flood light. I wired it to plug into an outlet. Flood light comes on when I plug it in and stays on. Seems as if the sensor isn't working. Do I have it wired...
look to see how you have it wired, most sensor lights have many wires to put together, if it is not wired already from factory, you need to look to see how you have it wired, most sensors have three wires one black one red and one white, black wire goes to power, red wire goes to lamp, white goes to neutral, after all is wired you should have only 3 wires a black a white and a green, black to power white to home neutral and green to ground
Oct 31, 2011 | Home
Car battery is dead. I have a Black and Decker Simple Start car battery recharger. I can figure out how to plug the outlet part into the wall but I do not know what to do about the part that goes onto...
You should have 2 wires with clips = one red that you clip on the Positive [ + ] post of the battery, this may be marked red on the cable. The other black clips to the Negitive [ - ] post of the battery.
Don't plug in the charger untill you clip the wires to the battery, make sure the charger is set to 12 volts. If your cherger has a cigar lighter wire just plug it in to the dash port.
May 09, 2011 | Honda Odyssey Cars & Trucks
I am replacing an existing switch/single outlet, the outlet was always live.the switch controlled a light. the existing sw was very old and only has connections on the back top.. The left had 2 white wires...
heatman101
Apr 20, 2011 | Pass & Seymour / Legrand 1595-2SWT...
I just bought a switch to control both fan speed and light control (dual switch) i hooked it up every thing worked fine. then to realize that the outlets that follow dont work. just as a clue on the...
The key seems to be that you changed wiring in the ceiling box.
I suggest you make a drawing of the wires before and after. Track the route that the Hot wire takes.
The key question is this: Does Hot wire from breaker box arrive in the ceiling box first? Or does it arrive in wall box first?
I think Hot from breaker arrives in wall box first. And from there Hot wire goes to ceiling box ... and from ceiling box the hot wire goes to other plugs in room. If this is true, you will be one wire short for installing fan control switch.
I always make a drawing of existing wires before starting, so I can put it back the way it was. It sounds like you got a good handle on which wire goes where.
We used to solve the one-wire-short problem by making a simple project bigger. Figure out which direction ceiling joist run. See if you can slide fish line from fan ceiling box over to wall. If that works. Over at the wall, chop small hole in ceiling so you can feed wire up to fish line. Pull wire over to ceiling box. Next, staple other end of wire along ceiling over to location above wall box. Chop another small hole so you can feed wire down to wall box. And then install beautiful crown molding to hide the mess, and paint the room so you need new furniture.
Oct 02, 2010 | Electrical Supplies
Hey there I have Dell 5650 Computer Speakers i turn the volume all the way down but still get high sound from speakers someone please help
how long has this been going on? you can also turn the volum down on your computer look to the lower right corner of you monitor. you will see a little horn. double click it to bring up your volum control lower as needed
Nov 13, 2009 | Dell 5650 Computer Speakers
I have a plug outlet that's powered by a three
Red wire is the live wire, black wire is the dead wire, white wire is the earth wire.
Now its the black and the red wire we are to play with. take a two wire cable, let the wires be red and black in the new cable, connect the red and the black cables of the new cable to the corresponding red and black wires of the old cable i.e. the new cable is to be connected parallel to the old cable(the connections can be made by ripping the old cable from any point) now connect a switch to the other end of the red wire. attach the terminal of the bulb to:
1) the the other terminal of the switch
2) the other end of the black wire
Sep 02, 2009 | Christmas Lights Etc Santa's Toy Truck
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Cingular 8125, dead as a doornail.
u can take a usb cable that not being used by any thing . save the end that plugs in to your computer . the end you would plug in to the device you can cut off and you need to use the red and black wires to jump start the battery so it will charge . on your battery you will see the - and + the black goes to the - and red to + can use electric tape to hold the exposed wire to it and plug the other end in to your computer for about a 5 to 10 mins and then put it in your phone and turn it on and charge it .if didnt work you might have to leave it hocked up to the usb cord on the battery longer what i did to mine and it turns on and works fine now had the same problem battery got to low and dead . so phone was froze and wouldnt start
Jun 12, 2009 | Cingular Wireless 8125 Smartphone
Having a hard time wiring a replacement taillight in 1999 Regal
You should just be able to find a hot wire 12v most likely the black wire, the ones with stripes are most likely tied in for trailoring lights. If there are only two wires 1 wire can go to a bolt or other bare metal to ground. You have a test light in the light itself, wire the 1 wire to a good ground and with the other end of the light wire touch to black wire with the appropriate turn signal on and when the light blinks in correct rhythem than viola, you have the correct wire. Direct current operates thru the light it doesn't have to be hooked up to alternate back to the power source like A/C. You could dissasemble the good/other turn signal and see which wire goes where, but with double element bulbs it is a 50/50 chance on which one is the turn lamp or the brke lamp. good luck.
Jan 11, 2009 | 1999 Buick Regal
Electrical Supplies Logo
89 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
