Question about Kenmore 74812 Gas Dryer
Kenmore 74812 Gas Dryer. Was told it ignites,
Kenmore 74812 Gas Dryer. Was told it ignites, clicks, but no 'whoosh'...hence no heat. The rods that go up inside the coils won't come down ..was told they should. Would need to replace whole burner assembly..but found I could get the Valve assembly with pipe and the repairman could reinstall. Was also told by a parts order man that I could replace the coils and that would fix it. However possibility gas could leak if I didn't know what I was doing. What do you suggest?
  • bbuehner Jun 22, 2009
    Not sure if it solved my problem yet...but it answered the situation and gave me the confidence to attack the problem...no need for qualified electrician/plumber for this one. Thanks.
  • 999 Answers
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Posted on Jun 22, 2009
My Samsung gas dryer displays error code u100. what is the meaning?
check igniter, flame sensor and gas valve and coils? if no gas from valve you will have no flame ignition. hence no heat, bad igniter will not ignite flame either, bad sensor will not detect flame hence no signal to ignite check all with multi meter
Feb 10, 2015 | Samsung Dryers
Dryer only works on 1 setting and is not heating
If your dryer is not heating assuming is a gas dryer. It could be due to The electrical fuse igniter is not working or no gas is going in. Need to remove the front bottom cover and check that the fuse is igniting when you turn on the dryer. You should hear a clicking noise just before the igniter turns red ( glowing) to receive the gas and create the flame to then produce the heat. If you are not able to see the fuse/igniter conduct this process, you might need to replace it.
Nov 16, 2013 | Kenmore Dryers
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2011 | Kenmore 74812 Gas Dryer
Our dryer won't heat up, there's a whooshing sound when you start it up and then after about 30 sec it clicks and then the noise goes away but no heat...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 30, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4t gas dryer will not heat. One load
The Sensor for heating element cut-off is bad. It wrongly detects the unit is overheated so it signals to inhibit the gas valve not to open. Since it is not opened, gas is not burnt through the manifold hence not heat why the machine is tumbling. Good luck.
Apr 18, 2010 | Dryers
Gas dryer not heating.
Commontly thermal fuse is damage need check and change if necessary.
Oct 02, 2009 | Dryers
Kenmore gas dryer won't heat up
Hello, your problem is going to be the flame sensor, this is located on the side of the tube where the flames are. if you have an ohms meter check it for condinity..you should find you don't get any reading on your meter, this will tell you it's bad..you should replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Jul 23, 2009 | Kenmore 74812 Gas Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Kenmore 74812 Gas Dryer Logo
88 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
